Home » Eclipse Projects » DTP » Need help using SQL parser
Need help using SQL parser [message #596393] Mon, 21 September 2009 08:57 Go to next message
aiquefernandez  is currently offline aiquefernandez
Hi.
I'm using the sql parser provided into the DTP package.
I'm trying to do a very simple execise: get the table name from a sql code. This could be:
question: select attribute from mytable
answer: mytable
I suppose that i can get it using the QuerySelect.getFromClause method, but I don't know how to parse an statement and get the QuerySelect from it.
Can anyone help me?, thanks.
Re: Need help using SQL parser [message #596400 is a reply to message #596393] Mon, 21 September 2009 20:20 Go to previous message
Brian Payton is currently offline Brian Payton
The answer partly depends on what kind of application you are creating.
If it is a Eclipse plugin application (that is, takes full advantage
of the Eclipse plugin environment) then I can send you some sample code.
If it's an RCP app. or a stand-alone Java app., then it will be more
difficult because of some plugin dependency issues.
Once you have the parser working, then you can use the "Helper" classes
in plugin org.eclipse.datatools.modelbase.sql.query to get whatever
information you need from the parsed query statement. For example,
"getTablesForStatement(QueryStatement stmt)" in the StatementHelper class.
aiquefernandez wrote:
> Hi.
> answer: mytable
Previous Topic:Need help using SQL parser
Next Topic:Problems with datatool again - No repository found containing....
Current Time: Thu May 23 16:30:41 EDT 2013
Powered by FUDForum. Page generated in 0.13825 seconds
