| Problem updating Bugzilla repository [message #595455] |
Sun, 14 December 2008 10:38 |
Jonathan Gossage Messages: 42 Registered: July 2009 |
Member |
I am using Eclipse 3.4.1 (Ganymede) with Mylyn 3.0.3. I am accessing my
own Bugzilla repository where Bugzilla is at 3.22.
Bugzilla is configured with usermatchmode=off.
If I use Mylyn to add a comment to a Bugzilla entry, when I submit the
update back to Bugzilla I get the following error.
Bugzilla was unable to make any match at all for one or more of the names
and/or email addresses you entered on the previous page.
Please go back and try other names or email addresses.
Assignee:
jgossage did not match anything
The actual name stored in the Bugzilla entry was jgossage@gossage.ca so it
appears that everything after the @ is being stripped off when the entry
is returned to Bugzilla.
Any suggestions as to what I can do to fix or workaround this problem.
FUDForum. Page generated in 0.01504 seconds
