Home » Eclipse Projects » XML Schema Definition (XSD) » 2 suggestions for XSD
2 suggestions for XSD [message #595428] Mon, 09 May 2005 07:34
Adam Flinton is currently offline Adam Flinton
Member
1) What schema.
Many schemas I have to work with are at the end of a long chain of
schemas i.e. I might be working on a schema which incudes a schema which
itself includes a schema etc.etc.
When you are then using the schema viewer & you get to an element which
is some distance into the model/tree you then have no idea which actual
schema contains the definition. What would be very usefull would be the
ability to see which actual schema contains a chosen type.
e.g. in the properties view you could include a further textbox which
says which schema this type resides in.
2) An example going all the way from XSD to a GEF editor.
I am looking at creating an XSD editor for an object model which is
expressed in XML. At present there is a tutorial for how to create an
EMF model from an xsd, and there are tutorials for how to create a GEF
editor from an EMF, but it would be usefull to have a tutorial where one
starts with an XSD & progresses right through to the GEF editor.
Preferably this would include best practice advice wrt how to separate
out the different levels such that if a schema changes then how to
ensure that only the minimal amount of work/refactoring will need to
occur at the GEF level.
Adam
Previous Topic:CWM and XSD
Next Topic:Problems with generating list types
Current Time: Sun May 26 03:32:04 EDT 2013
Powered by FUDForum. Page generated in 0.01807 seconds
