| TextNode does not contain the TargetNamespace [message #594537] |
Tue, 22 March 2005 10:46 |
Originally posted by: runinpanic.gmx.de
Hello
I have the following situation:
Using this Schema (the relevant part only):
<xs:schema xmlns:xs="http://www.w3.org/2001/XMLSchema"
xmlns="tests_localised_Schema"
targetNamespace="tests_localised_Schema">
<xs:complexType name="ct.alpha">
<xs:sequence minOccurs="1" maxOccurs="5">
<xs:element name="uno" type="st.uno" />
<xs:element name="duo" type="st.duo" />
<xs:element name="tres" type="ct.tres" />
</xs:sequence>
<xs:attribute name="opt" type="xs:token" />
</xs:complexType>
<xs:simpleType name="st.uno">
<xs:restriction base="xs:string">
<xs:enumeration value="hinz" />
<xs:enumeration value="kunz" />
</xs:restriction>
</xs:simpleType>
.... and reading a jDOM-object that is created using this Schema.
When getting the first TextNode (a jDOM "Text" object representing
"st.uno") I try to get the targetNamespace of the object using:
if (jdomObj instanceof Text) {
namespace = ((Text)jdomObj)
.getParentElement()
.getNamespaceURI();
The String "namespace" is empty ("").
Then I saw that this jDOM-object got its namespace from this code:
public ElementDeclaration(XSDElementDeclaration edecl, ...) {
String targetns = edecl.getTargetNamespace();
resultEle.setNamespace(Namespace.getNamespace(targetns));
Text txt = new Text(temp);
resultEle.addContent(txt);
checking the XSDElementDeclaration edecl I saw, that it did not hold a
targetNamespace (targetNamespace= null) but following the
"eContainer"-Attribute of "edecl" up to the complexType "ct.alpha"
taught me that the targetNamespace exists only in an upper level
edecl= XSDElementDeclarationImpl (id=33)
eContainer= XSDParticleImpl (id=116)
eContainer= XSDModelGroupImpl (id=142)
eContainer= XSDParticleImpl (id=151)
eContainer= XSDComplexTypeDefinitionImpl (id=158)
name= "ct.alpha"
targetNamespace= "tests_localised_Schema"
My question:
Is this correct? Is the targetNamespace not inherited from complexTypes
to hierarchically lower TextNodes?
FUDForum. Page generated in 0.02229 seconds
