Home » Eclipse Projects » Dali » Dali with Oracle DB
Dali with Oracle DB [message #593523] Tue, 10 April 2007 10:30
Eclipse User
Originally posted by: joemayo.us.ibm.com
I'm new to using eclipse and Dali. I installed eclipse 3.2 and the Dali
plugin .5 versions. I was trying to make a connection to an Oracle 10g
DB, but always get a failure to connect. I can connect to the same Oracle
DB from WebSphere running on the same system, also using the exact same
ojdbc14.jar file. The message I get when doing the test connection is
"Connection to Oracle failed:
oracle.jdbc.pool.OracleConnectionPoolDataSource". Any ideas what I'm
doing wrong? I can also connect in using the oracle enterrpise manager to
verify the userid and password that I am specifying are correct.
Joe
Previous Topic:WTP 2.0 M6 has been declared
Next Topic:Dali namespace change
Current Time: Sat May 25 22:35:46 EDT 2013
Powered by FUDForum. Page generated in 0.01693 seconds
