| Problem Running HazelCast [message #592725] |
Sat, 24 July 2010 05:56  |
No real name Messages: 4 Registered: July 2010 |
Junior Member |
I have a strange problem trying to use hazelcast in Virgo.
When deploying the Hazelcast bundle everything works out find, but when is deploy a bundle using classes from Hazelcast I get the following error:
Caused by: org.eclipse.virgo.kernel.osgi.framework.ExtendedNoClassDefFo undError: javax/management/DynamicMBean in KernelBundleClassLoader: [bundle=hazelcast_1.8.3] in KernelBundleClassLoader: [bundle=hazelcast_1.8.3]
at org.eclipse.virgo.kernel.userregion.internal.equinox.KernelB undleClassLoader.loadClass(KernelBundleClassLoader.java:141)
at java.lang.ClassLoader.loadClass(ClassLoader.java:248)
at java.lang.ClassLoader.defineClass1(Native Method)
at java.lang.ClassLoader.defineClassCond(ClassLoader.java:632)
at java.lang.ClassLoader.defineClass(ClassLoader.java:616)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.def ineClass(DefaultClassLoader.java:183)
at org.eclipse.virgo.kernel.userregion.internal.equinox.KernelB undleClassLoader.defineClass(KernelBundleClassLoader.java:23 9)
... 42 common frames omitted
at org.eclipse.virgo.kernel.userregion.internal.equinox.KernelB undleClassLoader.defineClass(KernelBundleClassLoader.java:24 3)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.defineC lass(ClasspathManager.java:576)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findCla ssImpl(ClasspathManager.java:546)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClassImpl(ClasspathManager.java:477)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClass_LockClassLoader(ClasspathManager.java:465)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClass(ClasspathManager.java:445)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.fin dLocalClass(DefaultClassLoader.java:211)
at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass (BundleLoader.java:381)
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInter nal(BundleLoader.java:457)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(Bund leLoader.java:410)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(Bund leLoader.java:398)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass(DefaultClassLoader.java:105)
at org.eclipse.virgo.kernel.userregion.internal.equinox.KernelB undleClassLoader.loadClass(KernelBundleClassLoader.java:135)
... 48 common frames omitted
Caused by: java.lang.NoClassDefFoundError: javax/management/DynamicMBean
... 60 common frames omitted
Caused by: org.eclipse.virgo.kernel.osgi.framework.ExtendedClassNotFoun dException: javax.management.DynamicMBean in KernelBundleClassLoader: [bundle=hazelcast_1.8.3]
at org.eclipse.virgo.kernel.userregion.internal.equinox.KernelB undleClassLoader.loadClass(KernelBundleClassLoader.java:139)
... 65 common frames omitted
Caused by: java.lang.ClassNotFoundException: javax.management.DynamicMBean
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInter nal(BundleLoader.java:494)
... 66 common frames omitted
DynamicMBean is a class in the com.springsource.mx4j-3.0.2 bundle, but after deploying this bundle I get the same error. Does anyone have an idea how to solve this problem? Could it be that the manifest of the Hazelcast bundle is incorrect?
FUDForum. Page generated in 0.01468 seconds
