Home » Eclipse Projects » DTP » JDBCSchemaLoader, JDBCTableLoader, etc. broken for many drivers.
JDBCSchemaLoader, JDBCTableLoader, etc. broken for many drivers. [message #592400] Mon, 04 August 2008 16:27
Chris Hines is currently offline Chris Hines
I have been researching the feasibility of using DTP as an enabling tool for
a general purpose database metadata reporting/management application. We
already use EMF, so bringing in DTP seems quite natural. I have encountered
a significant roadblock using the GenericJDBC infrastructure.
I have discovered that the code in the
org.eclipse.datatools.connectivity.sqm.loader package processes JDBC
ResultSets in a non-portable fashion, making it fail when using many JDBC
drivers, including the JDBC-ODBC bridge supplied as part of Sun's JVM.
The root problem is that DTP attempts to read the same column from a
ResultSet object more than once (for the same row), which is not guaranteed
to work as expected. The javadoc for ResultSet says: "For maximum
portability, result set columns within each row should be read in
left-to-right order, and each column should be read only once."
However, DTP uses the following code pattern:
[ Code snippet from JDBCTableLoader.loadTables(List containmentList,
Collection existingTables) ]
while (rs.next()) {
String tableName = rs.getString(COLUMN_TABLE_NAME); // first time
to retrieve table_name
if (tableName == null || isFiltered(tableName)) {
continue;
Table table = (Table) getAndRemoveSQLObject(existingTables, tableName);
if (table == null) {
table = processRow(rs); // eventually calls
tableFactory.initialize(table, rs) (see below)
if (table != null) {
containmentList.add(table);
else {
ITableFactory tableFactory = getTableFactory(rs
.getString(COLUMN_TABLE_TYPE));
if (tableFactory != null) {
tableFactory.initialize(table, rs); // retrieves table_name
a second time
if (table instanceof ICatalogObject) {
((ICatalogObject) table).refresh();
This pattern is pervasive throughout the
org.eclipse.datatools.connectivity.sqm.loader package.
Does anyone have any suggestions about how to work around this problem?
Should I enter this as a bugzilla entry?
Chris
Previous Topic:Reusing the server explorer in a ContainerCheckedTreeViewer
Next Topic:[ODA Ecore] Connection Profiles and Connection Properties
Current Time: Wed May 22 07:40:09 EDT 2013
Powered by FUDForum. Page generated in 0.07032 seconds
