Home » Eclipse Projects » Nebula » Grid - double click on column header
Grid - double click on column header [message #591816] Mon, 18 August 2008 03:08
Jacek Kolodziejczyk is currently offline Jacek Kolodziejczyk
Member
In my application a double click on a grid column header should open a
dialog. If I do this
grid.addMouseListener(new MouseAdapter() {
public void mouseDoubleClick(MouseEvent e) {
if (e.y < grid.getHeaderHeight()) {
// open dialog
then the dialog gets open also when I double click the column header
divider to auto size the column, which should not happen.
My current work around was to:
1) change the grid source file to have access to hoveringOnColumnResizer
private member, so in my client code I could do
&& !grid.hoveringOnColumnResizer)
// open dialog
2) change the beginning of grid.onMouseDoubleClick(MouseEvent e) method
like this
if (hoveringOnColumnResizer)
int dw = columnBeingResized.getWidth(); // added
columnBeingResized.pack();
dw -= columnBeingResized.getWidth(); // added
resizingColumn = false;
handleHoverOnColumnResizer(e.x-dw, e.y); // modified
return;
My question: is there a simpler way to achieve this and if not could we
have it implemented in the mainstream version?
Cheers
Jacek
Previous Topic:SWT Multiple tumb slider
Next Topic:Grid - double click on column header
Current Time: Thu May 23 07:41:13 EDT 2013
Powered by FUDForum. Page generated in 0.01526 seconds
