Home » Eclipse Projects » DSDP - Device Debugging » debug using eclipse
debug using eclipse [message #470171] Mon, 16 March 2009 12:12 Go to next message
fd101283 is currently offline fd101283
Hello Everybody,
I'm asking for help because i didn't find any help for using debug in
Eclipse.
I would like to use eclipse as debug IDE in my project.
I'm using WinARM and it's working quite well as compiler in eclipse.
Now i would use eclipse debug but it's not working whereas it's possible
to debug using inline command.
This is my .bat file which allow to DEBUG in inline command :
Code :
rem ###############Config Execute + USB port 2#######################
..\..\env\bin\M-win32\execute.exe -verbose
-dll=..\..\env\bin\M-win32\usbdbgport.dll
-port=USB2:SYSFREQ=324000000:STARTBAUD=38400:BAUDRATE=300000 0:RAMBASE=0x02004000
-reg=..\..\env\execute\ddr_init.rvs -quiet
rem ###############gdbserver + USB port 1#######################
cmd /C start /high ..\..\env\bin\M-win32\gdbserver.exe -verbose
-dll=..\..\env\bin\M-win32\jtagport.dll -port=USB1 -IP=127.0.0.1:12345
-verbose
rem ###############Lance insight#######################
c:\WinARM\utils\insight\bin\arm-elf-insight.exe
--directory=build\MB86H60\M-arm11-winarm
--command=build\MB86H60\M-arm11-winarm\.gdbinit --nx
"./build/MB86H60/M-arm11-winarm/hello_arm-g.elf"
So my question is: How can i integrate this debug in Eclipse ?
Help me please !
Thanks in advance.
Fred
Re: debug using eclipse [message #508119 is a reply to message #470171] Sat, 16 January 2010 01:33 Go to previous messageGo to next message
Clark Zhou is currently offline Clark Zhou
Maybe CooCox Team can help you if you want to try the new product named CoDebugger.
The website about it is http://www.coocox.com/CooCox_CoDebugger.htm
Make your choice freely, have good luck!
Re: debug using eclipse [message #591764 is a reply to message #470171] Sat, 16 January 2010 01:33 Go to previous message
Previous Topic:update site vs drops versions of the ip-xact editor
Next Topic:Debugging pthreads
Current Time: Wed May 29 02:20:14 EDT 2013
Powered by FUDForum. Page generated in 0.01472 seconds
