Home » Modeling » Epsilon » [EWL] Copy an element
icon5.gif  [EWL] Copy an element [message #548678] Thu, 22 July 2010 12:09 Go to next message
Rui Carlos  Gonçalves is currently offline Rui Carlos Gonçalves
I'm using the epsilon tools to draw graphs, where the graph nodes can have other graphs inside.
I have to copy a node (and all of its contents). Is there any simple way to do this without having to copy "manually" all (sub-)elements?
Re: [EWL] Copy an element [message #548852 is a reply to message #548678] Fri, 23 July 2010 05:18 Go to previous messageGo to next message
Dimitrios Kolovos is currently offline Dimitrios Kolovos
You can do this by using the EcoreUtil copy() method as demonstrated here:
http://eclipse.org/gmt/epsilon/examples/index.php?example=or g.eclipse.epsilon.examples.clone
Dimitris
Re: [EWL] Copy an element [message #549711 is a reply to message #548852] Tue, 27 July 2010 12:16 Go to previous messageGo to next message
Problem solved.
Re: [EWL] Copy an element [message #590947 is a reply to message #548852] Tue, 27 July 2010 12:16 Go to previous message
Problem solved.
http://cs.utexas.edu/~rcg
Previous Topic:[Eugenia] Drawing blocks with predefined inputs and outputs
Next Topic:[Eugenia] removing separator line before compartment
Current Time: Wed May 22 12:31:15 EDT 2013
Powered by FUDForum. Page generated in 0.02053 seconds
