| Re: DSDP/DSF build problems [message #590286] |
Thu, 10 January 2008 11:32 |
Martin Oberhuber Messages: 967 Registered: July 2009 |
The classpath that PDE has for your DSF plugins has might be
broken. Try "PDE Tools > Update classpath". Clean all projects
(without rebuild), close project, reopen project might also
help. You do have a Java 1.5 runtime installed that Eclipse can use?
(Window > Preferences > Java > Installed JREs)
AbstractUIPlugin should definitely be found, so somehow your
PDE / Classpath seems to be broken. I've seen that before on other
plugins, but never quite found what's causing this or how to workaround
it exactly... after some time of trying it eventually worked again.
Also copying the dsdp.dd newsgroup and the dsdp-dd-dev list.
Martin Oberhuber, Senior Member of Technical Staff, Wind River
Target Management Project Lead, DSDP PMC Member
http://www.eclipse.org/dsdp/tm
Jesper Eskilson wrote:
> Hi all,
> I'm trying to checkout the DSDP/DSF projects in order to study the
> implementations, but I get loads of build errors; things like
> "AbstractUIPlugin cannot be resolved".
>> Severity and Description Path Resource Location Creation
>> Time Id
>> org.eclipse.dd.dsf.mi.ui/src/org/eclipse/dd/dsf/mi/ui
>> DsfMIUIPlugin.java line 75 1199895367690 674
> I've got a couple of other plugins which work fine, so my Eclipse
> installation is not totally broken.
> Can anybody give a hint about where I should start looking?
> /Jesper
FUDForum. Page generated in 0.01539 seconds
