Home » Modeling » Epsilon » Accessing MapInfo structure from ECL
Accessing MapInfo structure from ECL [message #590235] Tue, 22 June 2010 09:42 Go to next message
Stephen Barrett is currently offline Stephen Barrett
Member
Hi guys,
I can't figure out how to put a value into a match's info map after a successful compare. I can see the (empty) structure in the debugger, but can't access it from ECL.
The Epsilon Book states that it is possible to do so from within the do part of a compare for the established match. Trouble is, I don't know how to get a hold of the "established match".
Many thanks,
--Stephen
Re: Accessing MapInfo structure from ECL [message #590255 is a reply to message #590235] Tue, 22 June 2010 10:00 Go to previous message
Dimitrios Kolovos is currently offline Dimitrios Kolovos
Hi Stephen,
You should be able to access the map using the implicit matchInfo
variable (and I should probably update the book :) ).
Dimitris
Stephen Barrett wrote:
> Hi guys,
> Many thanks,
> --Stephen
Previous Topic:[Patch] Clash between "default" variables and "default" (new?) keyword in Epsilo
Next Topic:[EOL, EWL, EVL] Ecore-aware Code Completion
Current Time: Sat May 18 10:33:54 EDT 2013
Powered by FUDForum. Page generated in 0.12549 seconds
