Home » Modeling » MOFScript » get external path of output
get external path of output [message #589908] Tue, 01 June 2010 04:19 Go to next message
yeliu is currently offline yeliu
If no path is given when defining file statement, can I get the externally defined root directory property in the transformation code? How? Thanks for any reply!
M
Re: get external path of output [message #590130 is a reply to message #589908] Mon, 21 June 2010 10:05 Go to previous message
Gøran K. Olsen is currently offline Gøran K. Olsen
There is no statement to do that in the language, but you can do this by
making an external java class, and call this one from MOFScript using the
java keyword.
The value is stored on the file properties of your transformation
(right-clicking the transformation will show the stored value) so you will
need to take a look at the MOFScript API.
G
Previous Topic:MOFScript installation on Ganymede
Next Topic:get external path of output
Current Time: Tue May 28 19:13:37 EDT 2013
Powered by FUDForum. Page generated in 0.01417 seconds
