Home » Modeling » MOFScript » output from java program
output from java program [message #589865] Tue, 06 April 2010 07:23 Go to next message
yeliu is currently offline yeliu
Is it possible that we direct the output location in the TestAPI.java rather than in the mofscript transformation?Thanks a lot!
M
Re: output from java program [message #589873 is a reply to message #589865] Mon, 12 April 2010 03:46 Go to previous message
Gøran K. Olsen is currently offline Gøran K. Olsen
Not sure what you mean by this, but it is possible to set the output
directory programatically in java and also on the file properties.
/G
Previous Topic:MOFScript called from Java API can only transform UML2 3.0.0?
Next Topic:output from java program
Current Time: Tue May 21 03:41:17 EDT 2013
Powered by FUDForum. Page generated in 0.01774 seconds
