Home » Modeling » MOFScript » transform uml2 2.1.0
transform uml2 2.1.0 [message #589822] Tue, 16 March 2010 10:10 Go to next message
yeliu is currently offline yeliu
If we want to transform uml2 2.1.0 input models, does anyone knows where we get the org.eclipse.uml.uml2-2.1.0.v.....jar so that we can add them to the classpath?Thanks a lot!
M
Re: transform uml2 2.1.0 [message #589836 is a reply to message #589822] Fri, 19 March 2010 10:27 Go to previous messageGo to next message
Gøran K. Olsen is currently offline Gøran K. Olsen
Look at this link, hopefully you will find what you are looking for.
If not, you could search the UML newsgroup and see if somebody else has
asked the same question.
G
Re: transform uml2 2.1.0 [message #589845 is a reply to message #589822] Fri, 19 March 2010 10:30 Go to previous message
This might help.
Haven't looked inside.
http://www.eclipse.org/downloads/download.php?file=/modeling /mdt/uml2/downloads/drops/NLS/2.0/NLpacks-uml2-runtime-2.0.1 .zip
Cheers
G
Previous Topic:call transformation from Java API
Next Topic:transform uml2 2.1.0
Current Time: Tue May 28 19:16:23 EDT 2013
Powered by FUDForum. Page generated in 0.06336 seconds
