Home » Eclipse Projects » Dali » [Persistence Properties] Mapping entity attributes is not working
[Persistence Properties] Mapping entity attributes is not working [message #588905] Thu, 29 June 2006 10:01
Bryan Hunt is currently offline Bryan Hunt
I've just downloaded RC1 (running on OS X using the latest download
from the Callisto site), and I'm trying to create a simple Entity. I
create the following:
@Entity
public class Foo
private int id;
I select id in the Persistence Outline and then select Map As: Id in
the Persistence Properties and nothing happens. If I manually add @Id
to the id attribute, the Persistence Properties changes to allow me to
set the other properties of an id field. Have I done something wrong
or is this broken? There are no entries in the error log.
Bryan
Previous Topic:ArrayIndexOutOfBoundsEx. w/o ManyToMany
Next Topic:ArrayIndexOutOfBoundsEx. w/o ManyToMany
Current Time: Tue May 21 03:14:16 EDT 2013
Powered by FUDForum. Page generated in 0.08841 seconds
