| ArrayIndexOutOfBoundsEx. w/o ManyToMany [message #588897] |
Thu, 29 June 2006 09:09 |
Juergen Zimmermann Messages: 21 Registered: July 2009 |
Junior Member |
Using the following class with Dali 0.5M5 yields the appended stack trace.
package de.hska.kundenverwaltung.db;
import static javax.persistence.GenerationType.AUTO;
import static javax.persistence.CascadeType.REMOVE;
import java.util.ArrayList;
import java.util.List;
import javax.persistence.Entity;
import javax.persistence.Table;
import javax.persistence.NamedQueries;
import javax.persistence.NamedQuery;
import javax.persistence.DiscriminatorColumn;
import javax.persistence.Embedded;
import javax.persistence.GeneratedValue;
import javax.persistence.Id;
import javax.persistence.Inheritance;
import javax.persistence.OrderBy;
import javax.persistence.QueryHint;
import javax.persistence.SequenceGenerator;
import javax.persistence.Version;
import javax.persistence.Column;
import javax.persistence.OneToMany;
import de.hska.bestellwesen.db.Bestellung;
@Entity
@Table(name="kunde")
@Inheritance
@DiscriminatorColumn(name="art", length=1)
@NamedQueries({
@NamedQuery(name = Kunde.KUNDE_ALL,
query = "FROM Kunde ORDER BY nachname"),
@NamedQuery(name = Kunde.KUNDE_BY_NACHNAME,
query = "FROM Kunde k WHERE k.nachname = :nachname",
hints={@QueryHint(name="org.hibernate.cacheable", value="true"),
@QueryHint(name="org.hibernate.cacheRegion",
value="org.hibernate.cache.StandardQueryCache")}),
@NamedQuery(name = Kunde.KUNDE_BY_NACHNAME_FETCH_BESTELLUNGEN,
query = "SELECT DISTINCT k FROM Kunde k LEFT JOIN FETCH
k.bestellungen b WHERE k.nachname = :nachname"),
@NamedQuery(name = Kunde.KUNDE_BY_ID_FETCH_BESTELLUNGEN,
k.bestellungen b WHERE k.id = :id"),
@NamedQuery(name = Kunde.KUNDE_BY_PLZ,
query = "FROM Kunde k WHERE k.adresse.plz = :plz")
public abstract class Kunde implements java.io.Serializable {
public static final String KUNDE_ALL = "kunde.all";
public static final String KUNDE_BY_NACHNAME = "kunde.byNachname";
public static final String KUNDE_BY_NACHNAME_FETCH_BESTELLUNGEN =
"kunde.byNachname.fetchBestellungen";
public static final String KUNDE_BY_ID_FETCH_BESTELLUNGEN =
"kunde.byId.fetchBestellungen";
public static final String KUNDE_BY_PLZ = "kunde.byPlz";
public static final String PRIVATKUNDE = "P";
public static final String FIRMENKUNDE = "F";
@Id
@GeneratedValue(strategy=AUTO, generator="kunde_sequence_name")
@SequenceGenerator(name="kunde_sequence_name",
sequenceName="kunde_sequence", allocationSize=1)
protected Long id = 0L;
@Version
protected int version = 0;
@Column(length=32, nullable=false)
protected String nachname = "";
@Column(length=32)
protected String vorname = "";
@Column(length=32)
protected String username = "";
@Column()
protected String password = "";
@Embedded
protected Adresse adresse;
@OneToMany(mappedBy="kunde")
@OrderBy("id ASC")
protected List<Bestellung> bestellungen = new ArrayList<Bestellung>();
@OneToMany(mappedBy="kunde", cascade={REMOVE})
@OrderBy("rollenBezeichnung ASC")
protected List<Rolle> rollen = new ArrayList<Rolle>();
public Kunde() {
super();
protected Kunde(Long id, String nachname, String vorname) {
super();
this.id = id;
this.nachname = nachname;
this.vorname = vorname;
public Long getId() {
return id;
public void setId(Long id) {
this.id = id;
public int getVersion() {
return version;
public void setVersion(int version) {
this.version = version;
public String getNachname() {
return nachname;
public void setNachname(String nachname) {
public String getVorname() {
return vorname;
public void setVorname(String vorname) {
public String getPassword() {
return password;
public void setPassword(String password) {
this.password = password;
public String getUsername() {
return username;
public void setUsername(String username) {
this.username = username;
public Adresse getAdresse() {
return adresse;
public void setAdresse(Adresse adresse) {
this.adresse = adresse;
public List<Bestellung> getBestellungen() {
return bestellungen;
public void setBestellungen(List<Bestellung> bestellungen) {
this.bestellungen = bestellungen;
public List<Rolle> getRollen() {
return rollen;
public void setRollen(List<Rolle> rollen) {
this.rollen = rollen;
abstract public String getArt();
public String toString() { ... }
public boolean equals(Object other) { ... }
Stacktrace:
!SESSION 2006-06-28 16:29:04.141
eclipse.buildId=M20060609-1217
java.version=1.5.0_07
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=de_DE
Command-line arguments: -os win32 -ws win32 -arch x86
!ENTRY org.eclipse.core.resources 4 2 2006-06-28 16:45:21.216
!MESSAGE Problems occurred when invoking code from plug-in:
"org.eclipse.core.resources".
!STACK 0
java.lang.ArrayIndexOutOfBoundsException: -1
at java.util.ArrayList.get(ArrayList.java:323)
at org.eclipse.jdt.core.dom.ASTNode$NodeList.get(ASTNode.java:1 206)
org.eclipse.dali.orm.adapters.java.NestedStringAnnotationEle mentAdapter.valuePair(NestedStringAnnotationElementAdapter.j ava:87)
org.eclipse.dali.orm.adapters.java.AbstractAnnotationElement Adapter.javaValue(AbstractAnnotationElementAdapter.java:232)
org.eclipse.dali.orm.adapters.java.AbstractAnnotationElement Adapter.updatePersElement(AbstractAnnotationElementAdapter.j ava:73)
org.eclipse.dali.orm.adapters.java.AbstractJavaJoinColumnMod elAdapter.updatePersSpecifiedName(AbstractJavaJoinColumnMode lAdapter.java:156)
org.eclipse.dali.orm.adapters.java.AbstractJavaJoinColumnMod elAdapter.updatePersModel(AbstractJavaJoinColumnModelAdapter .java:131)
org.eclipse.dali.orm.adapters.java.JavaJoinTableModelAdapter .updatePersJoinColumns(JavaJoinTableModelAdapter.java:179)
org.eclipse.dali.orm.adapters.java.JavaJoinTableModelAdapter .updatePersModel(JavaJoinTableModelAdapter.java:106)
org.eclipse.dali.orm.adapters.java.JavaMultiRelationshipMapp ingModelAdapter.updatePersModel(JavaMultiRelationshipMapping ModelAdapter.java:180)
org.eclipse.dali.orm.adapters.java.JavaPersistentAttributeMo delAdapter.updatePersAttributeMapping(JavaPersistentAttribut eModelAdapter.java:85)
org.eclipse.dali.orm.adapters.java.JavaPersistentAttributeMo delAdapter.updatePersModel(JavaPersistentAttributeModelAdapt er.java:52)
org.eclipse.dali.orm.adapters.java.JavaPersistentTypeModelAd apter.updatePersMappings(JavaPersistentTypeModelAdapter.java :215)
org.eclipse.dali.orm.adapters.java.JavaPersistentTypeModelAd apter.updatePersModel(JavaPersistentTypeModelAdapter.java:11 8)
org.eclipse.dali.orm.adapters.java.JavaPersistenceFileModelA dapter.addPersistentType(JavaPersistenceFileModelAdapter.jav a:170)
org.eclipse.dali.orm.adapters.java.JavaPersistenceFileModelA dapter.updatePrimaryType(JavaPersistenceFileModelAdapter.jav a:145)
org.eclipse.dali.orm.adapters.java.JavaPersistenceFileModelA dapter.updateModel(JavaPersistenceFileModelAdapter.java:73)
org.eclipse.dali.orm.adapters.java.JavaPersistenceFileModelA dapter.updatePersModel(JavaPersistenceFileModelAdapter.java: 62)
org.eclipse.dali.orm.impl.PersistenceFileImpl.engageModel(Pe rsistenceFileImpl.java:94)
org.eclipse.dali.orm.impl.PersistenceContainerImpl.getPersis tenceFile(PersistenceContainerImpl.java:313)
org.eclipse.dali.orm.impl.PersistenceContainerImpl$1.visit(P ersistenceContainerImpl.java:170)
at org.eclipse.core.internal.resources.Resource.accept(Resource .java:120)
at org.eclipse.core.internal.resources.Resource.accept(Resource .java:134)
org.eclipse.dali.orm.impl.PersistenceContainerImpl.buildInte rnalResources(PersistenceContainerImpl.java:185)
org.eclipse.dali.orm.impl.PersistenceContainerImpl$1.visit(P ersistenceContainerImpl.java:176)
org.eclipse.dali.orm.impl.PersistenceProjectImpl.buildResour ces(PersistenceProjectImpl.java:103)
org.eclipse.dali.core.internal.PersistenceBuilder.computePer sistenceFiles(PersistenceBuilder.java:156)
org.eclipse.dali.core.internal.PersistenceBuilder.fullBuild( PersistenceBuilder.java:142)
org.eclipse.dali.core.internal.PersistenceBuilder.build(Pers istenceBuilder.java:125)
org.eclipse.core.internal.events.BuildManager$2.run(BuildMan ager.java:603)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
org.eclipse.core.internal.events.BuildManager.basicBuild(Bui ldManager.java:167)
org.eclipse.core.internal.events.BuildManager.basicBuild(Bui ldManager.java:201)
org.eclipse.core.internal.events.BuildManager$1.run(BuildMan ager.java:230)
org.eclipse.core.internal.events.BuildManager.basicBuild(Bui ldManager.java:233)
org.eclipse.core.internal.events.BuildManager.basicBuildLoop (BuildManager.java:252)
org.eclipse.core.internal.events.BuildManager.build(BuildMan ager.java:285)
org.eclipse.core.internal.events.AutoBuildJob.doBuild(AutoBu ildJob.java:145)
org.eclipse.core.internal.events.AutoBuildJob.run(AutoBuildJ ob.java:208)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:58)
!ENTRY org.eclipse.core.resources 2 75 2006-06-28 16:45:21.256
!MESSAGE Errors during build.
!SUBENTRY 1 org.eclipse.dali.core 2 75 2006-06-28 16:45:21.256
!MESSAGE Errors running builder "Persistence Builder" on project hskaEJB.
!MESSAGE -1
!STACK 0
!ENTRY org.eclipse.ui.workbench 4 2 2006-06-28 16:45:39.022
"org.eclipse.ui.workbench".
!STACK 0
org.eclipse.dali.orm.impl.PersistenceModelManager.getPersist enceFile(PersistenceModelManager.java:134)
at org.eclipse.dali.core.DaliPlugin.getPersistenceFile(DaliPlug in.java:88)
org.eclipse.dali.orm.impl.PersistenceFileImpl.resolvePersist entType(PersistenceFileImpl.java:226)
org.eclipse.dali.orm.impl.RelationshipMappingImpl.getResolve dTargetEntity(RelationshipMappingImpl.java:232)
org.eclipse.dali.orm.adapters.java.JavaJoinTableModelAdapter .defaultName(JavaJoinTableModelAdapter.java:295)
org.eclipse.dali.orm.adapters.java.JavaTableModelAdapter.upd atePersDefaultName(JavaTableModelAdapter.java:91)
org.eclipse.dali.orm.adapters.java.JavaTableModelAdapter.pos tUpdatePersModel(JavaTableModelAdapter.java:87)
org.eclipse.dali.orm.adapters.java.JavaJoinTableModelAdapter .postUpdatePersModel(JavaJoinTableModelAdapter.java:111)
org.eclipse.dali.orm.adapters.java.JavaMultiRelationshipMapp ingModelAdapter.postUpdatePersModel(JavaMultiRelationshipMap pingModelAdapter.java:186)
org.eclipse.dali.orm.adapters.java.JavaPersistentAttributeMo delAdapter.postUpdatePersModel(JavaPersistentAttributeModelA dapter.java:57)
org.eclipse.dali.orm.adapters.java.JavaPersistentTypeModelAd apter.postUpdatePersMappings(JavaPersistentTypeModelAdapter. java:128)
org.eclipse.dali.orm.adapters.java.JavaPersistentTypeModelAd apter.postUpdatePersModel(JavaPersistentTypeModelAdapter.jav a:123)
org.eclipse.dali.orm.adapters.java.JavaPersistenceFileModelA dapter.postUpdatePersModel(JavaPersistenceFileModelAdapter.j ava:192)
org.eclipse.dali.orm.impl.PersistenceFileImpl.postEngageMode l(PersistenceFileImpl.java:98)
org.eclipse.dali.orm.impl.PersistenceContainerImpl.getPersis tenceFile(PersistenceContainerImpl.java:315)
org.eclipse.dali.ui.PersistenceManager.persistenceFileForInp ut(PersistenceManager.java:28)
org.eclipse.dali.ui.selection.TextEditorSelectionParticipant .getSelection(TextEditorSelectionParticipant.java:55)
org.eclipse.dali.ui.internal.selection.SelectionManager.sele ctPart(SelectionManager.java:103)
org.eclipse.dali.ui.internal.selection.SelectionManager.acce ss$3(SelectionManager.java:100)
org.eclipse.dali.ui.internal.selection.SelectionManager$Part Listener.partActivated(SelectionManager.java:229)
org.eclipse.ui.internal.PartListenerList2$1.run(PartListener List2.java:68)
at org.eclipse.core.runtime.Platform.run(Platform.java:843)
org.eclipse.ui.internal.PartListenerList2.fireEvent(PartList enerList2.java:53)
org.eclipse.ui.internal.PartListenerList2.firePartActivated( PartListenerList2.java:66)
org.eclipse.ui.internal.PartService.firePartActivated(PartSe rvice.java:77)
at org.eclipse.ui.internal.PartService.setActivePart(PartServic e.java:171)
org.eclipse.ui.internal.WorkbenchPagePartList.fireActivePart Changed(WorkbenchPagePartList.java:56)
at org.eclipse.ui.internal.PartList.setActivePart(PartList.java :126)
org.eclipse.ui.internal.WorkbenchPage.setActivePart(Workbenc hPage.java:3190)
at org.eclipse.ui.internal.WorkbenchPage.activate(WorkbenchPage .java:588)
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched( WorkbenchPage.java:2597)
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(Workben chPage.java:2521)
org.eclipse.ui.internal.WorkbenchPage.access$10(WorkbenchPag e.java:2513)
at org.eclipse.ui.internal.WorkbenchPage$9.run(WorkbenchPage.ja va:2498)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:67)
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2493)
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2478)
org.eclipse.jdt.internal.ui.javaeditor.EditorUtility.openInE ditor(EditorUtility.java:287)
org.eclipse.jdt.internal.ui.javaeditor.EditorUtility.openInE ditor(EditorUtility.java:164)
org.eclipse.jdt.internal.ui.actions.OpenActionUtil.open(Open ActionUtil.java:49)
at org.eclipse.jdt.ui.actions.OpenAction.run(OpenAction.java:19 0)
at org.eclipse.jdt.ui.actions.OpenAction.run(OpenAction.java:17 4)
org.eclipse.jdt.ui.actions.SelectionDispatchAction.dispatchR un(SelectionDispatchAction.java:267)
org.eclipse.jdt.ui.actions.SelectionDispatchAction.run(Selec tionDispatchAction.java:243)
org.eclipse.jdt.internal.ui.packageview.PackageExplorerActio nGroup.handleOpen(PackageExplorerActionGroup.java:306)
org.eclipse.jdt.internal.ui.packageview.PackageExplorerPart$ 4.open(PackageExplorerPart.java:651)
org.eclipse.jface.viewers.StructuredViewer$2.run(StructuredV iewer.java:817)
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:44)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:14 9)
org.eclipse.jface.viewers.StructuredViewer.fireOpen(Structur edViewer.java:815)
org.eclipse.jface.viewers.StructuredViewer.handleOpen(Struct uredViewer.java:1069)
org.eclipse.jface.viewers.StructuredViewer$6.handleOpen(Stru cturedViewer.java:1168)
org.eclipse.jface.util.OpenStrategy.fireOpenEvent(OpenStrate gy.java:249)
at org.eclipse.jface.util.OpenStrategy.access$2(OpenStrategy.ja va:243)
org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrate gy.java:283)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:928)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3348)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2968)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1914)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1878)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:419)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:95)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:78)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:92)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:68)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:400)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:177)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:336 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:280)
at org.eclipse.core.launcher.Main.run(Main.java:977)
at org.eclipse.core.launcher.Main.main(Main.java:952)
!ENTRY org.eclipse.jdt.core 4 2 2006-06-28 16:45:39.232
"org.eclipse.jdt.core".
!STACK 0
org.eclipse.dali.orm.adapters.java.JavaPersistenceFileModelA dapter.synchWithJavaDelta(JavaPersistenceFileModelAdapter.ja va:128)
org.eclipse.dali.orm.adapters.java.JavaPersistenceFileModelA dapter.handleEvent(JavaPersistenceFileModelAdapter.java:66)
org.eclipse.dali.orm.impl.PersistenceFileImpl.handleEvent(Pe rsistenceFileImpl.java:198)
org.eclipse.dali.orm.impl.PersistenceModelManager$ElementCha ngeProcessor.elementChanged(PersistenceModelManager.java:416 )
org.eclipse.dali.orm.impl.PersistenceModelManager$ElementCha ngeListener.elementChanged(PersistenceModelManager.java:391)
org.eclipse.jdt.internal.core.DeltaProcessor$3.run(DeltaProc essor.java:1448)
org.eclipse.jdt.internal.core.DeltaProcessor.notifyListeners (DeltaProcessor.java:1438)
org.eclipse.jdt.internal.core.DeltaProcessor.fireReconcileDe lta(DeltaProcessor.java:1304)
org.eclipse.jdt.internal.core.DeltaProcessor.fire(DeltaProce ssor.java:1262)
org.eclipse.jdt.internal.core.JavaModelOperation.run(JavaMod elOperation.java:760)
org.eclipse.jdt.internal.core.JavaModelOperation.runOperatio n(JavaModelOperation.java:779)
org.eclipse.jdt.internal.core.CompilationUnit.reconcile(Comp ilationUnit.java:1123)
org.eclipse.jdt.internal.ui.text.java.JavaReconcilingStrateg y$1.run(JavaReconcilingStrategy.java:97)
org.eclipse.jdt.internal.ui.text.java.JavaReconcilingStrateg y.reconcile(JavaReconcilingStrategy.java:82)
org.eclipse.jdt.internal.ui.text.java.JavaReconcilingStrateg y.initialReconcile(JavaReconcilingStrategy.java:172)
org.eclipse.jdt.internal.ui.text.CompositeReconcilingStrateg y.initialReconcile(CompositeReconcilingStrategy.java:114)
org.eclipse.jdt.internal.ui.text.JavaCompositeReconcilingStr ategy.initialReconcile(JavaCompositeReconcilingStrategy.java :120)
org.eclipse.jface.text.reconciler.MonoReconciler.initialProc ess(MonoReconciler.java:103)
org.eclipse.jdt.internal.ui.text.JavaReconciler.initialProce ss(JavaReconciler.java:331)
org.eclipse.jface.text.reconciler.AbstractReconciler$Backgro undThread.run(AbstractReconciler.java:170)
!ENTRY org.eclipse.jdt.core 4 4 2006-06-28 16:45:39.232
!MESSAGE Exception occurred in listener of Java element change notification
!STACK 0
FUDForum. Page generated in 0.06318 seconds
