| NullPointerException when validating JIRA Task Repository URL [message #588004] |
Tue, 26 February 2008 10:07 |
Carsten Kaiser Messages: 6 Registered: July 2009 |
Junior Member |
when I'm trying to connect to our JIRA Server
(https://intranet.valtech.de/vita) I am getting a NullPointerException. I
tried to enable debugging and provided a .options file as suggested, but
there is no further information available in the error log or the
debugging window.
Is it because of the HTTPS communication or the different name (vita
instead of jira!)?
I just have two execeptions concerning Mylyn in the error log occuring on
eclipse startup time:
org.osgi.service.prefs.BackingStoreException: Exception loading
preferences from:
/org.eclipse.mylyn.monitor.tests/.settings/org.eclipse.jdt.c ore.prefs.
org.eclipse.core.internal.resources.ProjectPreferences.load( ProjectPreferences.java:441)
org.eclipse.core.internal.preferences.EclipsePreferences.cre ate(EclipsePreferences.java:307)
org.eclipse.core.internal.preferences.EclipsePreferences.get Child(EclipsePreferences.java:412)
org.eclipse.core.internal.preferences.EclipsePreferences.int ernalNode(EclipsePreferences.java:541)
org.eclipse.core.internal.preferences.EclipsePreferences.nod e(EclipsePreferences.java:662)
at org.eclipse.core.resources.ProjectScope.getNode(ProjectScope .java:67)
org.eclipse.jdt.internal.core.JavaProject.getEclipsePreferen ces(JavaProject.java:1388)
org.eclipse.jdt.internal.core.JavaProject.getOptions(JavaPro ject.java:1573)
org.eclipse.jdt.internal.core.search.indexing.IndexManager.g etSourceElementParser(IndexManager.java:175)
org.eclipse.jdt.internal.core.search.indexing.IndexAllProjec t.execute(IndexAllProject.java:203)
org.eclipse.jdt.internal.core.search.processing.JobManager.r un(JobManager.java:392)
at java.lang.Thread.run(Unknown Source)
and
org.eclipse.core.internal.resources.ResourceException: Resource
'/org.eclipse.mylyn.monitor.tests/.settings/org.eclipse.jdt. core.prefs' is
not local.
org.eclipse.core.internal.resources.Resource.checkLocal(Reso urce.java:322)
at org.eclipse.core.internal.resources.File.getContents(File.ja va:286)
org.eclipse.core.internal.resources.ProjectPreferences.load( ProjectPreferences.java:436)
Any idea, how to get some more information about that problem?
Any help appreciated!
Thanks in advance!
CAK
FUDForum. Page generated in 0.01562 seconds
