Home » Eclipse Projects » XML Schema Definition (XSD) » Schema has not been resolved
Schema has not been resolved [message #587740] Thu, 27 May 2004 03:54
Mike Lischke is currently offline Mike Lischke
Member
Hi all,
I've got a problem when I moved my schemas from local harddisk to a web
server. There is this root schema (imported via an absolute path), which
includes 3 other schemas (which in turn import yet a couple of other
schemas). All the schemas are located in the same folder on the web server
(an IBM AIX machine with Apache). This works mostly well and fine except
for one schema, which does not get loaded. It is one of the schemas
imported by the root schema and I can't for my life find any reason for
the failing load. Using Internet Explorer or XML Spy the schema can be
accessed without problems. I checked exact spelling at least half a dozen
times as well as the user rights. The schema itself is not yet used, just
imported, but did not produce any error message when it was stored
locally, so I assume this is not the reason for the problem.
Any useful hint would be much appreciated.
Mike
www.soft-gems.net
Previous Topic:BaseType of a underived ComplexType
Next Topic:Schema has not been resolved
Current Time: Sat May 25 16:51:35 EDT 2013
Powered by FUDForum. Page generated in 0.11725 seconds
