| DSL toolkit book - problem when running tranformations [message #587233] |
Thu, 31 December 2009 11:26 |
Martin Baez Messages: 12 Registered: July 2009 |
Junior Member |
I am developing a dsl toolkit and trying to give support for running
some atl, qvto and xpand tranformations programatically.
I am a bit lost when trying to understand how invokations must be done
and found some problems when running the transformations:
1) The m2t tranformation(TransformMindmap2Csv class) was not running
beacuse the code is commented, I uncommented the code and used the
org.eclipse.emf.mwe plugins in order to compile the uncommented code,
but when I try to export a mindmap diagram to cvs nothing happens, after
some debug I found this issue reported for the WorkflowRunner
[ERROR]: Class not found: 'org.eclipse.xpand2.Generator'
What bundle am I missing?, I understood that the dsl sample must be used
with the ganymede version, but what version of xpand should I use?
2) I cannot run the transformations(mindmap to requirementes for
example) because the wizard reported this error:
"Cannot find imported module
'/org.eclipse.amalgam.examples.dnc.TransformDnc2Java.transfo rmationId' "
Any clue?, by the way the book is great!!
thanks in advance
colo
FUDForum. Page generated in 0.01808 seconds
