Home » Archived » OHF » SSL with NIST Server
SSL with NIST Server [message #587176] Tue, 26 August 2008 10:33
Stefan S. is currently offline Stefan S.
Hi Everybody!
I am tying to write some code in order to "speak" or "interact" with the
NIST Public Registry as well as the NIST Public Repository (both available
under http://129.6.24.109:9080/ or in the secure case
https://129.6.24.109:9443/) in Secure Mode, using TLS (SSL).
For me, this rose some great problems! ;)
Basically here is what I did:
- Writing a simple Axis2 Client, that connects to the registry/repository.
- Calling https://129.6.24.109:9443/ from within Firefox, trusting the
certificate, exporting the certificate and importing it into my Java
truststore.
This works so far - but I get an exception like
"org.apache.axis2.AxisFault: Received fatal alert: bad_certificate".
My guess is that I receive this message from the server, because I have no
(client-) certificate to identify myself - the client - against the NIST
server.
I have the same problem when trying to connect to
https://129.6.24.109:9443/ with my Firefox. There I get the error message:
YOUR SSL-Certificate could not be verified (Error-Code:
ssl_error_bad_cert_alert).
So my basic question is:
Where and How can I obtain a client certificate to communicate with the
NIST server using SSL?
Hope someone can help me or provide some clever advices! ;)
Thanks in Advance for both your time and your knowledge!
Greetings
Stefan
P.S.: I am aware that this question is not really linked up to OHF, but
you guys are always so friendly that I thought about giving it a try! ;)
Previous Topic:XCA with NIST's public registry
Next Topic:SSL with NIST Server
Current Time: Thu May 23 10:56:44 EDT 2013
Powered by FUDForum. Page generated in 0.01526 seconds
