Home » Modeling » Epsilon » [EuGENia] Compartment gets list layout for not annotated elements.
[EuGENia] Compartment gets list layout for not annotated elements. [message #586825] Thu, 25 February 2010 17:28
Piotr Jaworowski is currently offline Piotr Jaworowski
I've noticed strange eugenia behaviour for compartment element. If you'll create a diagram from below code, SomeProcess figure will have list Layout in its body, is it correct behaviour? the problem is not solved even if I'll add @compartment(layout="free") for that element.
@namespace(uri="http://a.b.c/x/y/Z", prefix="p")
package process;
@gmf.node(label="name")
abstract interface Nameable {
attr String name;
@gmf.diagram(foo="bar")
class ProccessesHolder {
val SomeProcess[*] processes;
class SomeProcess extends Nameable {
@gmf.compartment(foo="bar")
val Stepable[*] participants;
abstract class Stepable extends Nameable {
@gmf.link(target.decoration="arrow", style="dash")
val Reference target;
class StepParticipant extends Stepable {
attr String additionalInfo;
class Step extends Stepable {
@gmf.link(source="source", target="target", style="dot", width="2", label="stepValue")
class Reference {
attr String stepValue;
ref Stepable source;
ref Stepable target;
I was playing with the code and all started to work correctly with following code:
package process;
class Nameable {
attr String name;
class Reference {
I've looked throught the bugzilla but i didn't find and bug for that.
Piotr
Previous Topic:GMF-Epsilon transformation
Next Topic:Mixing Other Frameworks
Current Time: Sun May 26 03:04:15 EDT 2013
Powered by FUDForum. Page generated in 0.02266 seconds
