| openSecure project [message #586367] |
Mon, 12 July 2010 05:06  |
Amel Jakupovic Messages: 52 Registered: March 2010 |
Member |
After lots of try-fails :) we finaly create a project:
1. All client is in Riena (2.0.2)
2. Platform IDE STS on ubuntu 10.4
3. Database Postgre
4. SpringDM
5. Remote RMI (can be use any protocol, just change xml:) )
6. Riena appl have been started from ubuntu and Windows and working
7. All reports have been created with jasper
8. All views and controllers are created with our framework:
8.1. You create XML, and framework build view, and connect everything in controller
8.2. Framework view and controller can be simple ovveride
8.3. Example: for simple CRUD function you must:
8.3.1. Create simple xml
8.3.2. Create table, service and you are ready the go
9. Project is about security and view organization in Riena
Now Riena team, can I and where to post project (piace by piace) and tutorial about everything how to configure platform, riena, etc...
thank you
p.s. Riena client is working wonderful on TouchScreen Asus, like POS :).
| Re: openSecure project [message #586393 is a reply to message #586367] |
Mon, 12 July 2010 09:01   |
Christian Campo Messages: 578 Registered: July 2009 |
Am 12.07.10 11:06, schrieb Amel Jakupovic:
> 3. Database Postgre
> 4. SpringDM
> controller
> thank you
Hi Amel,
if you like to talk about what you did, I think a blog post would be good. Create an account at blogger.com or anywhere
you like and start writing about it, post screen shots. Pretty much the same on what Ekke is doing
http://ekkes-corner.org/ .
If you like to post your application as a sample that other can download, you could try Eclipse Labs
(http://code.google.com/a/eclipselabs.org/hosting/). I am not sure what the rules are there, but your code must be EPL.
Or what else do you have in mind ?
- christian
FUDForum. Page generated in 0.01511 seconds
