Home » Modeling » Papyrus » Bug in stereotype's property setting: MARTE, sw_SchedulableResource, entrypoints
Bug in stereotype's property setting: MARTE, sw_SchedulableResource, entrypoints [message #586331] Fri, 12 June 2009 09:41
Terrasson Marc is currently offline Terrasson Marc
Hi there.
I am using the profile MARTE.
I have applied the "SW_SchedulableResource" stereotype on a class.
Then, when I tried to set the stereotype's property "entrypoints", Papyrus
gave me the following error (see bellow).
I can't even choose any value, the error occurs right after I cliked on
the "add a new element" button.
MARTE specification (it's pretty big) :
http://www.omgmarte.org/Documents/Specifications/08-06-09.pd f
Thanks.
Marc.
Error :
Unhandled event loop exception
at com.cea.papyrus.profile.utils.Util.getLabel(Unknown Source)
at com.cea.papyrus.profile.utils.Util.getStringArrayFromList(Un known
Source)
com.cea.papyrus.profile.ui.composites.PropertyComposite.addB uttonPressed(Unknown
Source)
com.cea.papyrus.core.profiles.PropertyComposite.addButtonPre ssed(Unknown
Source)
com.cea.papyrus.profile.ui.composites.DecoratedTreeComposite $AddButtonlistener.mouseUp(Unknown
Source)
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:206)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:938)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3682)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3293)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2389)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2353)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:169)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 508)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:447)
at org.eclipse.equinox.launcher.Main.run(Main.java:1173)
Previous Topic:Can EMFText be used inside Papyrus?
Next Topic:Bug in stereotype's property setting: MARTE, sw_SchedulableResource, entrypoints
Current Time: Sun May 19 10:02:11 EDT 2013
Powered by FUDForum. Page generated in 0.01484 seconds
