Home » Modeling » Epsilon » [EUGENIA] Questions about examples.friends
[EUGENIA] Questions about examples.friends [message #586312] Tue, 16 February 2010 08:03
Joaquin Cañadas is currently offline Joaquin Cañadas
Hi Dimitris,
I have a problem with the friends example. I am using the pre-packaged
Eclipse Galileo Modeling distribution.
I downloaded the two zip archive(s) of friends example (friends and
friends.figure) from this page:
http://eclipse.org/gmt/epsilon/examples/index.php?example=or g.eclipse.epsilon.eugenia.examples.friends
After importing them on Eclipse, I generated ALL and generated Diagram
Code.
My first problem was that the generated friends.diagram project had
errors because it did not find the figures package. I solved it adding
the friends.figure project to the friends.diagram Java build path.
Afther that, I run other Eclipse instance. When I create a new friends
diagram, the editor opens but it does not allow to draw a person,
however it presents a pop-up with this error:
An error has occurred. See error log for more details.
figures/PersonFigure
I imagine that I forgot any step of the process... moreover I do not
know whether the code generator uses the mirrored.gmfgraph file
in.figure/models folder. What is the aim of that file ?
Thank you in advance.
Joaquín
Previous Topic:how to access .gmfgen root node?
Next Topic:how to access .gmfgen root node?
Current Time: Sat May 18 21:24:45 EDT 2013
Powered by FUDForum. Page generated in 0.01489 seconds
