When I run the test, I get no documents returned ... and no errors. I
suspect that some of the information I'm using is not correct, because
if I use the "Blue Panther Administration Portal" at http://lswin10.dfw.ibm.com:9081/IBMXDSRegistry/index.jsp, I can query on
the patient id above and get 193 document references returned.
Can someone verify the consumer information I listed above?
