Home » Modeling » Epsilon » Transform UML Class diagram to UML Class diagram
Transform UML Class diagram to UML Class diagram [message #585834] Sun, 07 February 2010 13:00 Go to next message
BALLESTA Mising name is currently offline BALLESTA Mising name
I would like using ETL to transform:
-From an UML Class diagram representing an Entity/relationShip conceptual data model;
----Entity moded as UML Classes
----Associations modeled as UML associations
-to another UML Class diagram representing an Relational base
----Relational Tables modeled as classes
--------Add primary key attribute
----Foreign keys and Referential integrity modeled as navigable associations.
In order to transform from/to UML model, I need to have an UML metamodel in Ecore.
My question:
-Where can i find an UML metamodel in Ecore in order to feed in Epsilon ?
-How to set up the environment ?
The goal is to do the same kind of transformation of the Epsilon example "Transform an OO model to a DB model with ETL" but using source and target UML Models.
Best regards
Bernard
Re: Transform UML Class diagram to UML Class diagram [message #585843 is a reply to message #585834] Sun, 07 February 2010 13:56 Go to previous messageGo to next message
Itamar is currently offline Itamar
Member
To use Ecore's UML meta-model you need to install the UML2 plugin (and you'll probably want UML2Tools too, for the graphical editor).
To install these plug-ins, add the http://download.eclipse.org/releases/galileo update-site and look under the Modeling branch.
Once you install it, the UML meta-model URI can be obtained using:UMLPackage.eNS_URI (or just hard-coded: "http://www.eclipse.org/uml2/3.0.0/UML").
Re: Transform UML Class diagram to UML Class diagram [message #585849 is a reply to message #585843] Sun, 07 February 2010 14:29 Go to previous message
Dimitrios Kolovos is currently offline Dimitrios Kolovos
Hi Bernard,
Adding to Itamar's advice, you can browse the EClasses of the UML
metamodel (and their contents) using the EPackage Registry view provided
by Epsilon
( http://www.eclipse.org/gmt/epsilon/doc/articles/epackage-reg istry-view/).
Please let us know if you need more help with this.
Dimitris
Previous Topic:Transform UML Class diagram to UML Class diagram
Next Topic:[EUGENIA] Different types of diagrams like UML2 Tools
Current Time: Sat May 25 11:08:05 EDT 2013
Powered by FUDForum. Page generated in 0.01726 seconds
