Home » Eclipse Projects » Riena » Riena & Formtoolkit
Riena & Formtoolkit [message #585248] Wed, 05 May 2010 03:04 Go to next message
Ngwa Ambe Elvis is currently offline Ngwa Ambe Elvis
In trying to use formtoolkit in my moduleviews in get into following problematik.
protected void basicCreatePartControl(Composite parent) {
toolkit = new FormToolkit(parent.getDisplay());
toolkit.adapt(parent);
form = toolkit.createForm(parent);
I get following errors
org.eclipse.riena.ui.swt.lnf.LnFUpdater Cannot create an instance of "org.eclipse.ui.internal.forms.widgets.TitleRegion"
org.eclipse.riena.core.util.ReflectionFailure: Error creating instance for org.eclipse.ui.internal.forms.widgets.TitleRegion with parameters [FormHeading {}, 570425344]!
at org.eclipse.riena.core.util.ReflectionUtils.newInstance(Refl ectionUtils.java:147)
Any help is welcomed.
Thanks in advance
Re: Riena & Formtoolkit [message #585274 is a reply to message #585248] Wed, 05 May 2010 04:25 Go to previous message
Stefan Liebig is currently offline Stefan Liebig
I assume that you are using Riena 1.2?
I think the problem is that the TitleRegion does not have the expected
constructor, which has two parameters which are the parent and the
style. It only has a constructor with the parent.
Please use our latest version. This should have fixed this issue.
Tschüß,
Stefan
> problematik.
> at
> Any help is welcomed. Thanks in advance
Previous Topic:How Can I Remove / Modify Riena Logo?
Next Topic:Riena on server-side with DI
Current Time: Sat May 25 17:26:43 EDT 2013
Powered by FUDForum. Page generated in 0.01953 seconds
