I try to install Riena 1.2 in a target platform (or Eclipse <- just a try) based on 3.5.2 Linux/GTK. But I encounter the following problems:
1. Riena Core SDK (TP only) and the Examples apperas two times in the update site (wich one is the right)
2. If I install it info the target platform it tells me that I need the org.eclpse.core.runtime in version 0.0.0!?!?!
Am 16.04.10 14:28, schrieb Dirk Hoffmann:
> Is there something I doing wrong?
> Dirk
hi dirk,
you need both versions. One is the binary and the other contains the source bundles. They are in different features
unfortunatelly under the same name. (despite I highly recommend using Eclipse 3.6M6 and Riena 2.0M6)
Still you can and should also be able to install Riena 1.2. Riena needs core.runtime 0.0.0 (meaning any version 0.0.0 or
higher).
