Home » Eclipse Projects » Riena » AbstractMasterDetailsComposite
AbstractMasterDetailsComposite [message #584139] Mon, 23 November 2009 05:25 Go to next message
Ngwa Ambe Elvis is currently offline Ngwa Ambe Elvis
HI,
is it possible to change the signature of some methods in the AbstractMasterDetailsComposite class to protected. Such as:
->createMaster()
->createTableComposite()
Main reason, i would like to position the buttons in horizontal row at the bottom. May be you have an idea of achieving this without having to overwrite the createMaster and subsequently createTableComposite(since its private) methods.
Thanks in advance.
Another alternative will be to implement a new MasterDetailComposite
Re: AbstractMasterDetailsComposite [message #584165 is a reply to message #584139] Mon, 23 November 2009 06:32 Go to previous messageGo to next message
Hi, found a solution to my problem.
In future I will see to it that i take closer look at APIs before complaining.
For those interested, you can reposition the button in the MasterDatetailComposite by overriding the method createButtons(Composite parent) by just returning null. You are then responsible of adding the buttons to the ui where ever you wish(You most add the three compulsory button new, remove and apply).
For more docu take a closer look at the method createButtons(what i should have done).
Re: AbstractMasterDetailsComposite [message #584186 is a reply to message #584165] Mon, 23 November 2009 08:55 Go to previous message
Christian Campo is currently offline Christian Campo
Ngwa Ambe Elvis schrieb:
> Hi, found a solution to my problem. In future I will see to it that i
> button new, remove and apply). For more docu take a closer look at the
no problem, cool that you found a solution yourself....
There are at least 2 demos for the MasterDetail with different buttons. So you can see how that works.
We also had requests for different update strategies, update on apply button, or update on focus lost in the detail fields.
christian
Previous Topic:Riena 1.2.0.M3 is available
Next Topic:Riena 1.2.0.M3 is available
Current Time: Fri May 24 17:25:16 EDT 2013
Powered by FUDForum. Page generated in 0.04001 seconds
