Home » Modeling » Epsilon » Problem using EVL on a UML 2.1 meta-model?
Problem using EVL on a UML 2.1 meta-model? [message #583511] Sat, 05 December 2009 11:55 Go to next message
Barak  is currently offline Barak
Hi all,
I've been trying to write a simple EVL constraint for a UML 2.1 diagram. For this purpose I followed this tutorial http://www.eclipse.org/gmt/epsilon/doc/articles/evl-gmf-inte gration/ with slight changes:
First of all, the TIP written at the beginning of the tutorial recommends changing the .gmfgen model configuration if Quote:
> you have not implemented your editor using EuGENia
How do I change these configurations for a UML editor that wasn't implemented by me?
Step 3 - I'm using an EVL constraint which is compatible for the UML meta-model:
context Class {
critique constraint1 {
check {
'checked'.println();
return not(self.name = 'Foo');
message: "problem with class"
fix { title: "DummyFix" do {} }
} and added its path to the binary build tab.
Step 4 - I've added the org.eclipse.epsilon.evl.emf.validation extension and created a new constraint binding in it with the following details:
namespaceURI: http://www.eclipse.org/uml2/3.0.0/UML
constraints: the path of the *.evl from Step 3
added the org.eclipse.ui.ide.markerResolution extension and created two markerResolutionGenerator with the following details:
class: org.eclipse.epsilon.evl.emf.validation.EvlMarkerResolutionGe nerator
markerType: org.eclipse.uml2.uml.editor.diagnostic
markerType: org.eclipse.emf.ecore.diagnostic
Now I opened a new eclipse instance, created in it a UML 2.1 class diagram, drew a class with the name "Foo", saved the diagram, clicked "Validate" and nothing happened (There was nothing new under the "Problems" view and no indication for a constraint violation was shown on the diargram).
What am I doing wrong?
Re: Problem using EVL on a UML 2.1 meta-model? [message #583526 is a reply to message #583511] Sun, 06 December 2009 13:18 Go to previous message
Dimitrios Kolovos is currently offline Dimitrios Kolovos
Hi Barak,
I've reproduced this. Could you please open a bugzilla to keep track of
this and post the link here?
Dimitris
Barak wrote:
> Hi all,
> implemented by me?
> meta-model: context Class {
> check {
> } message: "problem with class"
> namespaceURI: http://www.eclipse.org/uml2/3.0.0/UML constraints: the
> nerator
> nerator
> on the diargram).
> Thanks
Previous Topic:resolving a reference to an object, instead of obtaining a copy
Next Topic:resolving a reference to an object, instead of obtaining a copy
Current Time: Mon May 20 23:04:58 EDT 2013
Powered by FUDForum. Page generated in 0.02019 seconds
