Home » Eclipse Projects » Riena » riena security start
riena security start [message #583446] Mon, 21 September 2009 06:49
Waldi  is currently offline Waldi
Member
Dear all,
i try to start with riena security. Now I try out the security sample in
the SWT ExampleApplication.product. The vm arguments I set to
-Djava.security.auth.login.config==${workspace_loc}\org.ecli pse.riena.security.simpleservices\config\sample_jaas.config
I start the Riena Sample App Server und try to login with john and john.
The following exception appears:
!ENTRY org.eclipse.equinox.security 4 0 2009-09-21 12:46:41.132
!MESSAGE Could not locate JAAS Configuration with name "Remote", verify
that the configuration exists and is non-empty.
Mon Sep 21 12:46:41 CEST 2009 ERROR [main] Bundle
org.eclipse.core.runtime Message: Could not locate JAAS Configuration
with name "Remote", verify that the configuration exists and is
non-empty., Code: 0, Plugin: org.eclipse.equinox.security
!ENTRY
org.eclipse.equinox.security 4 0 2009-09-21 12:46:41.167
!MESSAGE Could not locate JAAS Configuration with name "other", verify
with name "other", verify that the configuration exists and is
I run it unter Linux.
I check sample_jaas.config. It looks like:
/** Login Configuration for the JAAS Sample Application **/
Remote {
org.eclipse.equinox.security.auth.module.ExtensionLoginModul e
required debug="true"
extensionId="org.eclipse.riena.example.client.remoteSecurity ";
Can you helb me?
CU Waldi
Previous Topic:Use Ridgets without the UI concept
Next Topic:riena security start
Current Time: Fri May 24 14:09:01 EDT 2013
Powered by FUDForum. Page generated in 0.05317 seconds
