| RSE connection [message #583392] |
Sat, 12 June 2010 22:08  |
Mark Messages: 3 Registered: May 2010 |
Junior Member |
I've just begun with RSE. Just downloaded and installed. I've attempted to make a remote connection to a linux host (from my linux box) using "ssh only".
I can connect to the same remote host using ssh and sshfs from a terminal. However not through rse. RSE does something weird: it changes the name of the host into upper case. I tested the upper case name using ssh in a terminal: it didn't work.(In both cases (RSE and terminal) I got an invalid password.
I'd have to presume that the upper case makes the host name invalid. I can't believe that someone else hasn't tried this and found this to be a problem. If there is another possible source for the error please let me know...
Mark
FUDForum. Page generated in 0.01510 seconds
