Home » Modeling » Epsilon » Eugenia don't create gmfmap,gmftool,gmfgraph...come in an infinite loop
Eugenia don't create gmfmap,gmftool,gmfgraph...come in an infinite loop [message #583305] Fri, 27 November 2009 18:56 Go to next message
marco  is currently offline marco
Member
Hi Dimitris
I'm trying to use Eugenia for Diagram Partition.
I wanted to create a new diagram involving only types.
The following EMF file is what I use.
compared to the previous diagram, I moved the annotation @ gmf.diagram from SoftwareArchitecture to TypesSpecification
I use Eugenia but don't work...
seems kind that come in an infinite loop ... and do not understand why.
someone tell me why?
regards
marco
@namespace(uri="http://a0.ecore", prefix="A0")
@gmf(foo="bar")
package A0;
@namespace(uri="core", prefix="core")
package core {
class SAComponent extends Component {
@gmf.node(figure="rounded",label="name")
class SAConnector extends Component {
@gmf.node(figure="a0_editor.diagram.figures.TypeFigure",label= "name")
class Type extends PropertyHolderElement {
@gmf.link(color="250,100,100")
ref TypedElement[*]#type implementations;
ref Type[*]#subtypes supertypes;
@gmf.link(color="50,200,100",target.decoration="closedarrow ")
ref Type[*]#supertypes subtypes;
@gmf.node(figure="rounded",label = "name")
class SAInterface extends InteractionPoint, ArchitecturalElement {
attr SAInterfaceDirection direction;
val Behavior[*] behavior;
@gmf.node(figure="rectangle",label="name")
abstract class Component extends ConnectableElement, ArchitecturalElement {
@gmf.compartment(foo="bar", collapsible="true")
val ArchitecturalElement[*] subElement;
@gmf.link(style="solid", width="2")
class SAChannel extends SARelationship {
abstract class Behavior extends Element {
abstract class Business extends Element {
abstract class Development extends Element {
abstract class Element {
attr String name;
attr String description;
val Development development;
val Business business;
@gmf.link(source="from",target="to",label="name")
abstract class Link extends PropertyHolderElement, TypedElement {
attr LinkNavigability navigability;
ref ConnectableElement[1] from;
ref ConnectableElement[1] to;
ref Component fromContext;
ref Component toContext;
abstract class ConnectableElement extends Element {
@gmf.node(figure="rounded", label="name")
abstract class TypedElement extends Element {
ref Type[*]#implementations type;
abstract class PropertyHolderElement extends Element {
val Property[*] properties;
@gmf.node(label="name,type,value", figure="rectangle", label.pattern="{1} {0} : {2}")
class Property extends Element {
attr PropertyType type;
attr String value;
enum SAInterfaceDirection {
input = 0;
output = 1;
inputOutput = 2;
@gmf.node(figure="rectangle", size="20,20", label="name",
label.placement="external", label.icon="false")
abstract class InteractionPoint extends ConnectableElement {
enum LinkNavigability {
bidirectional = 0;
unidirectional = 1;
@gmf.link(target.decoration="arrow",style="dash")
class SARelationship extends Link, ArchitecturalElement {
abstract class Architecture extends PropertyHolderElement {
val Group[*] groups;
class SoftwareArchitecture extends Architecture {
abstract class ArchitecturalElement extends PropertyHolderElement, TypedElement {
@gmf.node(figure="ellipse",label = "name")
class Group extends Element {
@gmf.link(style="dot",tool.small.path="/a0_editor.edit/icons/full/obj16/Members.gif ",tool.large.path="/a0_editor.edit/icons/full/obj16/Members.gif ")
ref Element[*] members;
@gmf.diagram(foo = "bar")
class TypesSpecification {
val Type[*] types;
class SAType extends Type {
enum PropertyType {
string = 0;
int = 1;
boolean = 2;
reference = 3;
float = 4;
double = 5;
short = 6;
long = 7;
any = 8;
class SAStructuredType extends SAType {
@gmf.compartment(collapsible="false")
@gmf.link(style="solid")
class SABinding extends SARelationship {
Re: Eugenia don't create gmfmap,gmftool,gmfgraph...come in an infinite loop [message #583313 is a reply to message #583305] Mon, 30 November 2009 05:47 Go to previous message
Dimitrios Kolovos is currently offline Dimitrios Kolovos
Hi Marco,
I've reproduced this. I'll try to figure out what goes wrong later on
today and get back to you.
Dimitris
marco wrote:
> Hi Dimitris
> regards
> marco
> @gmf(foo="bar")
> package A0;
> package core {
> @gmf.link(color="250,100,100") ref TypedElement[*]#type
> implementations;
> attr String name;
> attr String value;
> input = 0;
> output = 1;
> inputOutput = 2;
> bidirectional = 0;
> unidirectional = 1;
> TypedElement {
> val Type[*] types;
> enum PropertyType {
> string = 0;
> int = 1;
> boolean = 2;
> reference = 3;
> float = 4;
> double = 5;
> short = 6;
> long = 7;
> any = 8;
Spread the word: http://www.eclipse.org/gmt/epsilon/spreadtheword
Follow Epsilon on Twitter: http://twitter.com/epsilonews
Previous Topic:Showing EVL validation in "Problems" view: how to obtain it?
Next Topic:Eugenia: Starters/ideas to automate GMF generation?
Current Time: Thu May 23 02:27:08 EDT 2013
Powered by FUDForum. Page generated in 0.09400 seconds
