| PDE + AJDT = OMGBBQ [message #583248] |
Tue, 28 September 2004 15:17 |
Ben Youngdahl Messages: 6 Registered: July 2009 |
Junior Member |
I have a plugin, "X", which needs to be woven with an Aspect "Foo" defined
in plugin "A." All plugins have a dependency on AJDE. Plugin "X" depends on
plugin "A." "Foo" is defined such that its pointcuts will definitely select
joinpoints in "X."
It seems I have to get "Foo" onto the aspect path for plugin "X". I can only
do that by using a JAR. Therefore, I must have plugin "A" generate a JAR.
Generating a JAR in "A" means a "\bin" directory isn't updated, just the
JAR. This appears to have serious issues with self-hosting in Eclipse;
specifically, I can't seem to get Eclipse to use JAR-based rather than
"\bin" classpathes when running in a runtime workbench launch config.
Thanks for any suggestions you can give.
FUDForum. Page generated in 0.07228 seconds
