| Syntax errors in file not detected [message #583175] |
Tue, 23 March 2010 00:47  |
Sheela Messages: 52 Registered: July 2009 |
Member |
We have created an IDE based on eclipse framework. It works fine when used locally. However when I open files from a remote location, the syntax errors in those files do not appear in the problems view. How do I link the remote editor page with the problems view?
Please shed some light on this.
Sheela
| Re: Syntax errors in file not detected [message #583350 is a reply to message #583175] |
Thu, 03 June 2010 15:11  |
David McKnight Messages: 229 Registered: July 2009 |
Hi Sheela,
I'll assume that, when you're opening files from a remote location, you're
using RSE as opposed to using EFS. Note that remote files in RSE are
different from local files in an Eclipse project since, unlike files in a
typed project, there is no implied tooling associated with an arbitrary
remote file. That said, when you open a file via RSE, you're downloading it
into a temporary project, RemoteSystemsTempFiles. I'm not sure which tools
you're using to generate markers in the problems view, but I suspect that
the tools are only associated with resources in typed projects.
Dave
"Sheela" <sheela_kalyanpur@infosys.com> wrote in message
news:ho9h56$ska$1@build.eclipse.org...
> Sheela
FUDForum. Page generated in 0.01579 seconds
