Home » Modeling » Epsilon » Question about using enumerated types!
Question about using enumerated types! [message #583163] Tue, 24 November 2009 11:28
Lucas Schubert is currently offline Lucas Schubert
Hey,
I'm new in this group, so if it is a newbie question, sorry! :p
I'm trying to set a enumerated type value to a property in my target model (ECore) but it is not working.
I've tried to do it like it is written in the Epsilon Book and also using ".instance" at the end. But it is still not working.
The code line:
aMetricResult.type := QueryResult!MetricTypes#mtNumberOfChildren.instance;
The error Msg:
EXCEPTION: Cannot find enumeration literal MetricTypes#mtNumberOfChildren in model QueryResult.
If I don't set this field, the transformation works fine.
I've registered the Ecore model. (Magic Draw (UML) converted to eCore model).
I'm executing the transformation using an ant file.
The Epsilon Version is : 0.8.8
So I would like to ask if some of you knows what I may be doing wrong! :p
Thanks a lot in advance!
Lucas
Previous Topic:[Eugenia] Subdiagrams
Next Topic:Re: Question about using enumerated types!
Current Time: Sun May 19 20:11:05 EDT 2013
Powered by FUDForum. Page generated in 0.01628 seconds
