Home » Eclipse Projects » EGit » Freeze when committing
Freeze when committing [message #582524] Thu, 19 August 2010 11:00 Go to next message
Leif Bladt is currently offline Leif Bladt
Hi folks,
if I trigger a commit on my multi-module project, my Eclipse freezes for several minutes. This happens since a couple of weeks (with the nightly-build) and is very annoying.
Where can I retrieve more information (log files) or switch on, for example, debug messages?
Re: Freeze when committing [message #582539 is a reply to message #582524] Thu, 19 August 2010 17:31 Go to previous message
Robin Rosenberg is currently offline Robin Rosenberg
leif.bladt@inxmail.de wrote:
> Hi folks,
There is a log in yourworkspace/.metadata/.log, which is also viewable
int the Errors view. If you can verify that the same problem occurs
with a new workspace, then please report as a bug in bugzilla. If you can
tell when it started going wrong, even better.
-- robin
Previous Topic:Way of reseting the icon decorations
Next Topic:Versioning conflict must be resolved from command line
Current Time: Sat May 18 16:38:47 EDT 2013
Powered by FUDForum. Page generated in 0.01556 seconds
