Home » Modeling » Epsilon » Cannot reproduce EVL-GMF tutorial
Cannot reproduce EVL-GMF tutorial [message #582208] Fri, 16 October 2009 14:48 Go to next message
Michalis Famelis is currently offline Michalis Famelis
I'm trying to do validation according to the http://www.eclipse.org/gmt/epsilon/doc/articles/evl-gmf-inte gration/, but I'm failing miserably. I'm trying to reproduce the filesystem example, using the example .emf and .evl files.
I'm a bit suspicious of the way I'm doing Step 1. For creating an integration plugin I go:
New -> Project -> Plug-in development -> Plug-in project
From there I just keep the default wizard settings and don't use any of the template example plugin wizards. Then I edit the manifest according to the instructions.
However, when I fire up a new Eclipse instance, I don't get a Diagram->Validate option.
What am I doing wrong?
Thanks in advance! :)
Re: Cannot reproduce EVL-GMF tutorial [message #582224 is a reply to message #582208] Fri, 16 October 2009 14:55 Go to previous messageGo to next message
I should have mentioned I use Eclipse Galileo.
Re: Cannot reproduce EVL-GMF tutorial [message #582239 is a reply to message #582224] Fri, 16 October 2009 15:54 Go to previous message
Dimitrios Kolovos is currently offline Dimitrios Kolovos
Hi Michali,
Thanks for reporting this! I've reproduced the problem under Galileo.
The Diagram->Validate option seems to be missing indeed in Galileo (this
does not appear to be an EVL issue but a GMF one). I'll investigate and
get back to you shortly.
Dimitris
Previous Topic:Set source.decoration in a link when navigability is BIDIRECTIONAL
Next Topic:Cannot reproduce EVL-GMF tutorial
Current Time: Sat May 18 14:27:16 EDT 2013
Powered by FUDForum. Page generated in 0.01691 seconds
