Home » Modeling » Epsilon » Link property with 4 field...i don't set all [URGENT]
Link property with 4 field...i don't set all [URGENT] [message #581534] Wed, 07 October 2009 12:23
marco  is currently offline marco
Member
@namespace(uri="http://dually/a0", prefix="A0")
@gmf(foo="bar")
package A0;
@gmf.link(source="from",target="to")
abstract class Link extends Element{
ref InteractionPoint[1] from;
ref InteractionPoint[1] to;
ref Component fromContext;
ref Component toContext;
@gmf.node(figure="rectangle",label="name")
abstract class Component extends Element{
@gmf.affixed(foo="bar")
val InteractionPoint[*] points;
@gmf.node(figure="rectangle", size="20,20", label="name",
label.placement="external", label.icon="false")
class InteractionPoint extends Element{
class SAcomponent extends Component {
@gmf.node(figure="rounded",label="name")
class SAconnector extends Component {
@gmf.link(target.decoration="rhomb",source.decoration="rhomb ")
class SABinding extends Link {
class Element {
attr String name;
attr String description;
@gmf.diagram (foo="bar")
class A0Spec extends Element {
val Element[*] elements;
this is my metamodel.
I have the following problem.
I can not set the fromContext and toContext when I create a link.
I have a component to a InteractionPoint B (posted on the board).
I have another component C with a InteractionPoint D (posted on the board).
Once you create the link from B to D I have the following properties.
from = B
fromContext = A
to = D
toContext = C
told me to use feuture sequence initializer but I can not understand what to do.
I think the problem there is because the link is between two InteractionPoint and I need to go back to the component that has on board (poster) the InteractionPoint
please can someone help me?
I realize the editor for my thesis and I was a bit late.
thank
marco
Previous Topic:Recursive operation - use of Sequence.add()
Next Topic:Visibility of link when i click group element in the diagram
Current Time: Tue May 21 09:57:17 EDT 2013
Powered by FUDForum. Page generated in 0.01518 seconds
