Home » Eclipse Projects » Eclipse 4 » XWT + lazy content provider
XWT + lazy content provider [message #581365] Wed, 01 September 2010 02:08 Go to next message
guls is currently offline guls
Some newbie questions...
Is it possible to populate a jFace viewer using a lazy content provider if I am using XWT declarative data binding. If it is not possible to do it declarative fashion, what are the other options to map a large data set to a jface tableviewer, if I am using XWT.
What is the best way to integrate a UI created with XWT to a data source which is a relational database? It is mostly for viewing purposes and not editing.
Re: XWT + lazy content provider [message #581411 is a reply to message #581365] Fri, 03 September 2010 04:48 Go to previous message
Yves YANG is currently offline Yves YANG
We have not tested with lazy content provider. In theory, it should work.
Please make a try. There is another solution is to use virtual table. The
last solution has the same status as previous. Please make a test and keep
inform us. If it doesn't work, please fill a bug.
Best regards
Yves YANG
<remeshb_1@yahoo.co.uk> wrote in message
news:i5kql2$4i7$1@build.eclipse.org...
> editing.
Previous Topic:XWT + lazy content provider
Next Topic:When are my (injected) POJO methods called?
Current Time: Sat May 25 19:12:17 EDT 2013
Powered by FUDForum. Page generated in 0.01978 seconds
