| Trying to Validate using SAX [message #581263] |
Mon, 01 December 2003 07:48 |
Originally posted by: svkk2.hotmail.com
I am trying to Validate a XML file against a XSD file. I am having errors
with the Schema and language Properties
import java.io.*;
import org.xml.sax.*;
import org.xml.sax.helpers.DefaultHandler;
import javax.xml.parsers.SAXParserFactory;
import javax.xml.parsers.ParserConfigurationException;
import javax.xml.parsers.SAXParser;
public class TestClass extends DefaultHandler
/* static final String JAXP_SCHEMA_LANGUAGE =
"http://java.sun.com/xml/jaxp/properties/schemaLanguage";
static final String W3C_XML_SCHEMA =
"http://www.w3.org/2001/XMLSchema";
static final String JAXP_SCHEMA_SOURCE =
"http://java.sun.com/xml/jaxp/properties/schemaSource";
public static void main(String argv[])
try {
// Use an instance of ourselves as the SAX event handler
DefaultHandler handler = new TestClass();
// Use the validating parser
SAXParserFactory factory = SAXParserFactory.newInstance();
factory.setValidating(true);
factory.setNamespaceAware(true);
SAXParser saxParser = factory.newSAXParser();
saxParser.setProperty
("http://java.sun.com/xml/jaxp/properties/schemaLanguage",
"http://www.w3.org/2001/XMLSchema");
"http://java.sun.com/xml/jaxp/properties/schemaSource",
"file://C:/Program Files/Eclipse/iEngine2.1.xsd");
}catch (SAXParseException spe) {
// Error generated by the parser
System.out.println("\n** Parsing error"
+ ", line " + spe.getLineNumber()
+ ", uri " + spe.getSystemId());
System.out.println(" " + spe.getMessage() );
// Use the contained exception, if any
Exception x = spe;
if (spe.getException() != null)
x = spe.getException();
x.printStackTrace();
} catch (SAXException sxe) {
// Error generated by this application
// (or a parser-initialization error)
Exception x = sxe;
if (sxe.getException() != null)
x = sxe.getException();
} catch (ParserConfigurationException pce) {
// Parser with specified options can't be built
pce.printStackTrace();
} //catch (IOException ioe) {
// I/O error
//ioe.printStackTrace();
System.exit(0);
This code is giving me the following errors
org.xml.sax.SAXNotRecognizedException: Property:
at org.apache.crimson.parser.XMLReaderImpl.setProperty(Unknown Source)
at org.apache.crimson.jaxp.SAXParserImpl.setProperty(Unknown Source)
at testPack.TestClass.main(TestClass.java:54)
I have checked the Sun's website for explanation but nothing helps. Anyone
can figure out what the error is? Does my classpath have to be set to
something specific, or are there any external libraries to be included?
FUDForum. Page generated in 0.01647 seconds
