Home » Eclipse Projects » DSDP - Target Management » RSE flat single level view, no directories
RSE flat single level view, no directories [message #580322] Mon, 13 April 2009 07:19
exceptione is currently offline exceptione
Member
My question:
I've installed RSE.
No matter what type of connection I make, be it ssh or ftp, I am able to
connect to the target (Linux server), I get the following situation
below the Files node in the treeview
• below My Home shows all entries (be it files or directories) as files.
This means that directories are not shown as expandable nodes; I only
see the name of the dir. I cannot open files.
• below Root only "/" is shown, nothing more.
The default filter which I seem to be not able to change is ./*
Is this the cause?
I tried this on 2 different hosts, and i get the same situation. I don't
understand a * of it.
► An observation from a newcomer
As newcomer I installed the Remote System Explorer (RSE).
A first comment: it looks like RSE isn't meant for end users. The
provided tutorials and information deal with developing for TM. Using
the update manager to install the RSE is also not optimal: you need to
select different items from different releases and the end user doesn't
know exactly whether you select the correct things.
I recommend to split your website structure based on the audience:
• TM/RSE end users: how to install, how to use. This section should be
prominent.
• Developing for/with TM/RSE: tutorials, apis etc
Previous Topic:How to get remote process PID
Next Topic:serverPortRange recommendation
Current Time: Sun May 19 09:35:41 EDT 2013
Powered by FUDForum. Page generated in 0.01576 seconds
