| Cross debugging [message #579456] |
Wed, 04 March 2009 11:22 |
Phil Longstaff Messages: 4 Registered: July 2009 |
Junior Member |
I have compiled a copy of gdb 6.8 as a cross-debugger from linux/i86 to
linux/ppc for an embedded target. If I install CDT and RSE, I can set up
a connection to the target and remote launch configuration. I can then
change the command from 'gdb' to '/to/path/my-cross-gdb' and set up the
solib path to match the cross-built libraries, and can do successful
debugging on the target.
I'm now trying to package this up into a plugin which will automatically
set the command and path correctly. My plugin has an extension to the
CDebugger and CDebuggerPage extension points, but I don't see my debugger
in the drop down in the remote c++ launch configuration dialog. Ideally,
I'd like my debugger to be the default if the remote target type is
linux/ppc, but don't see remote platform cpu in the connection parameters.
I don't know what I'm missing.
Phil
FUDForum. Page generated in 0.01554 seconds
