Home » Eclipse Projects » DSDP - Mobile Tools for Java (MTJ) » Is there a step-by-step to install MTJ in Eclipse
Is there a step-by-step to install MTJ in Eclipse [message #579272] Sat, 30 January 2010 16:45 Go to next message
chupalo  is currently offline chupalo
I've been using Eclipse to code in Java for a couple of years now, nothing too crazy. I am running Eclipse 3.4.2, and have two JRE's configured that I can swamp amongst (JRE 1.5 & 1.6).
Anyway, I am now taking a class in mobile application development and want to install MTJ in Eclipse and I can't see that it seems that easy and straightforward.
Can someone point me to a step-by-step for noobs to get this done. I've attempted the HELP > Software Updates... > then adding the site: http://download.eclipse.org/dsdp/mtj/updates/1.0.1/stable/
When I go to install I get errors stating that "no repository found containing" a bunch of folders. I've attempted to find the downloads for these folders but don't see any that exactly match this error list. I've found a bunch of jar files that look close but I know there has to be a clearer way here.
Can someone help?
Frank
Re: Is there a step-by-step to install MTJ in Eclipse [message #579311 is a reply to message #579272] Mon, 01 February 2010 09:15 Go to previous message
Gustavo de Paula is currently offline Gustavo de Paula
Member
probably the easiest way is to just download eclipse pulsar (www.eclipse.org/pulsar). it has eclipse 3.5 + MTJ already pre-installed.
if you want to install from yourself, i would suggest that you move to eclipse galileo (3.5). since mtj 1.0.1 it only runs on it (as far as i remember)
after all install is ok, please refer to http://help.eclipse.org/galileo/nav/18 to setup your environment. if you have questions plewase send to the forum
gep
Previous Topic:Is there a step-by-step to install MTJ in Eclipse
Next Topic:Obfusator question
Current Time: Mon May 20 12:33:47 EDT 2013
Powered by FUDForum. Page generated in 0.01641 seconds
