Home » Eclipse Projects » Swordfish » Failed to create web services using swordfish tooling UI
Failed to create web services using swordfish tooling UI [message #520738] Sun, 14 March 2010 23:14 Go to next message
No real name is currently offline No real name
I tried to create a web service via File > New > Others > Swordfish > JAX-WS Service from WSDL , but once I clicked the finish button, I always get these kind of errors:
Could not initialize class com.sun.xml.bind.DatatypeConverterImpl
or
javax.xml.datatype.DatatypeConfigurationException: Provider org.apache.xerces.jaxp.datatype.DatatypeFactoryImpl not found
I have tried to copy jaxb and xerces jars to plugin directory, but did not help.
can anyone advise a solution?
Re: Failed to create web services using swordfish tooling UI [message #520756 is a reply to message #520738] Mon, 15 March 2010 04:22 Go to previous messageGo to next message
Jürgen Kindler is currently offline Jürgen Kindler
Member
Hi No Real Name,
this sounds a bit like a problem inside the embedded CXF.
Which OS, Eclipse & JDK are you using ?
Cheers
Juergen
Re: Failed to create web services using swordfish tooling UI [message #520774 is a reply to message #520756] Mon, 15 March 2010 06:05 Go to previous messageGo to next message
I am using ubuntu jaunty, eclipse 3.5, Sun java JDK 6, Swordfish 0.9.1.
Re: Failed to create web services using swordfish tooling UI [message #521009 is a reply to message #520774] Tue, 16 March 2010 04:22 Go to previous messageGo to next message
Member
Hi again,
I have tried to reproduce this (on the VM I have available: Ubuntu Hardy Heron with Java 1.6.0_07 and Galileo), but I did not get any errors.
So in principle it should work on Ubuntu (my installation is very fresh; only Galileo and Swordfish have been installed after setting it up).
Did you do any changes to the Java installation?
Cheers
Juergen
Re: Failed to create web services using swordfish tooling UI [message #521110 is a reply to message #521009] Tue, 16 March 2010 09:46 Go to previous messageGo to next message
No, it was a typical java installation I set up ages ago, and I have had no problem using it for other java applications. The thing is, I don't even know where to start looking at the problem, Google does not help in this regard. It seems to be a dependency issue, but should I specify in a particular swordfish plug-in?
Re: Failed to create web services using swordfish tooling UI [message #521158 is a reply to message #521110] Tue, 16 March 2010 11:32 Go to previous messageGo to next message
Member
Hm, ... maybe you can post parts of the Eclipse log file...
Do you see some stacktraces connected to the problems there?
The other thing I would like to understand is about the Eclipse installation itself. Which Galileo version / package are you using?
Which additional features are installed?
[Updated on: Wed, 17 March 2010 02:39]
Report message to a moderator
Re: Failed to create web services using swordfish tooling UI [message #521537 is a reply to message #521158] Wed, 17 March 2010 19:33 Go to previous messageGo to next message
Thanks for your kind information. I do have a bunch of extra stuff installed in my previous Eclipse. You might be right, some of them might prevent my swordfish from working properly. It works now when I get another Eclipse running with swordfish only.
icon7.gif  Re: Failed to create web services using swordfish tooling UI [message #521572 is a reply to message #521537] Thu, 18 March 2010 02:38 Go to previous messageGo to next message
Member
I'm happy to hear that it works for you now. If you don't mind I would ask you to share the information about the configuration that did not work for you.
Cheers
Jürgen
Re: Failed to create web services using swordfish tooling UI [message #531605 is a reply to message #520738] Wed, 05 May 2010 10:15 Go to previous messageGo to next message
Peter Stadler is currently offline Peter Stadler
I had the same problem on Galileo. The Installation of BPEL Designer solved my problem. I am new with eclipse and I have no idea why it works now.
see: http://wiki.eclipse.org/Swordfish_Documentation:_Installing_ BPEL_Designer_in_Galileo
Peter
Re: Failed to create web services using swordfish tooling UI [message #531764 is a reply to message #531605] Thu, 06 May 2010 01:38 Go to previous messageGo to next message
Member
Hello Peter,
I want to try to reproduce this. Could you give me more details about the Eclipse you use, please?
(Version, type, possibly features you added before trying Swordfish?)
Kind regards
Jürgen
Re: Failed to create web services using swordfish tooling UI [message #532379 is a reply to message #531764] Sun, 09 May 2010 07:36 Go to previous messageGo to next message
Hello Jürgen,
I hope the following information will help. I copied the Installation History and Configuration Details.
Greetings
Peter
Current Installation:
Acceleo SDK (Incubation) 0.8.1.v200909161003
Apache MyFaces Trinidad Tag Support (Optional) 2.2.0.v20090517-20-7w311A1636
ATL SDK - ATLAS Transformation Language SDK 3.0.2.v201001190421
Axis2 Tools 1.1.0.v200905242110-78-FBpDZRDE6FdPdLYYe
BPEL Visual Designer 0.4.0
BPMN Project Feature 1.2.0.201002010854
CDO Model Repository SDK 2.0.0.v200906160459
Dali Java Persistence Tools 2.2.2.v200911250220-7L7OAPFBBoPS0TBgXV1je
Dali Java Persistence Tools - EclipseLink Support (Optional) 2.2.2.v200911250220-65A9AkF77g8OFL7BB7
Data Tools Platform Enablement Extender SDK 1.7.2.v200909251450-7I8r7XFE9JfFs0wYgDsB0wKAZttV
Data Tools Platform Extender SDK 1.7.2.v200909251450-7O9I7bFD0IVIPElYvW1YBTgDFOgj
Dynamic Languages Toolkit - iTcl Development Tools 1.0.0.v20090613-1432-3--9oA55V5L9K28LC_
Dynamic Languages Toolkit - Mylyn Integration 1.0.0.v20090610-1638-1--7w311_17261119
Dynamic Languages Toolkit - Ruby Development Tools 1.0.0.v20090610-1638-7B--E_EkMO1PJYsAZIz-C
Dynamic Languages Toolkit - TCL Development Tools 1.0.1.v20090903-2153-7D-4EB7sQSMTibkCiTAc
Dynamic Languages Toolkit - XOTcl Development Tools 1.0.0.v20090610-1638-4-0_kE77g7W_V29IEA
Eclipse C/C++ Development Tools 6.0.2.201002161416
Eclipse Communication Framework SDK 3.0.1.v20090916-2238
Eclipse Faceted Project Framework 3.1.1.v200908111817-37718s733L4C585I7F
Eclipse Faceted Project Framework JDT Enablement 3.1.1.v200908111817-37718s733L56485K8H
Eclipse IDE for SOA Developers 1.2.2.20100216-1730
Eclipse Java EE Developer Tools 3.1.1.v200908101600-7_7EGrjFQRwRb4P511ebObS5XZhq
Eclipse Modeling Framework Data Integrity Frameworks Extender SDK 1.3.1.v20090819-1457-4778_90GCMOEJccDOSfSYw5qz-LE
Eclipse Web Developer Tools 3.1.1.v200908120400-7R77FStEVw2z07WtDz-OZrhL5C-3
Eclipse XSL Developer Tools 1.0.2.v200908271520-7R7T8sFIhIehWg454rq_U1
Ecore Tools SDK (Incubation) 0.9.0.v200906221231
EMF - Eclipse Modeling Framework SDK 2.5.0.v200906151043
EMF Compare SDK 1.0.1.v200909161031
EMF Teneo Eclipselink SDK 1.0.0.v200909151729-31184E43QYgJOQQRZuYI_PFWWGHN
EMF Teneo Hibernate SDK 1.1.1.v200909151729-42188FAFLgfKYI_KdreDKXR_SEFC
Graphical Modeling Framework SDK 2.2.2.v20100209-2200-7C7I-BLxlyz-uojrqeOfnk4eytKd
Java Emitter Templates (JET) SDK 1.0.2.v201001281539-4-5866Eq9sMGMeJfZQJZPL
JavaScript Developer Tools 1.1.2.v200908101420-77-FGDCcNBDjBXMoBbFb
JST Server Adapters 3.1.1.v20090813-777HFDPCcNBBz0BjJU4BA8
JST Server Adapters 3.1.0.v20090311c-20-7w311A1422c
JST Server UI 3.1.1.v20090817-7A2FBb9xFaHovXGLUCTMQ2355
JST Web UI 3.1.1.v200908121609-7E77FBiDlwYcICNdz-5z-9PGqZCy
Mint SDK (Incubation) 0.8.0.v200906161513
MWE SDK (Incubation) 0.7.2.v200908120417
Mylyn Bridge: C/C++ Development 5.1.0.201002161416
Net4j Signalling Platform SDK 2.0.0.v200906160348
Object Constraint Language (OCL) 2.0 Extender SDK 1.3.0.v200901271800-787B8aA3PRRgQUXlKwbe1tshdIma
Operational QVT SDK 2.0.1.v20090701-2200-7N-5CLrGiFfYqKJ7FOaWVaJlXLqT
PHP Development Tools (PDT) SDK Feature 2.1.1.v20090707-1108-51584QACJCRCUeNRkNYbOJecWK9O
Rich Ajax Platform SDK (RAP) 1.2.2.20100126-1129
SCA Tools Feature 2.0.1.201002010854
SCA Tools Feature - FraSCAti support 2.0.1.201002010854
SCA Tools Feature - SAWSDL support 2.0.1.201002010854
SCA Tools Feature - Tuscany support 2.0.1.201002010854
SCA Tools Feature - XML Editor 2.0.1.201002010854
SOA Policy Editor Feature 1.1.0.201002010854
SOA Tools Platform 2.0.1.200909171139
STP Intermediate Model BPMN Support Feature 1.1.0.201002010854
STP Intermediate Model Core Feature 1.1.0.201002010854
STP Intermediate Model Runtime Support Feature 1.1.0.201002010854
STP Intermediate Model SCA Support Feature 1.1.0.201002010854
Swordfish Registry (Incubation) 0.9.2.v201002111330
Swordfish Samples 0.9.2.v201002111330
Swordfish SOA Runtime Core Components (Incubation) (Required) 0.9.2.v201002111330
Swordfish Tooling (Incubation) 0.9.2.v201002111330
UML2 Extender SDK 3.0.1.v200908281330
UML2 Tools SDK (Incubation) 0.9.0.v200906190654
Web Page Editor (Optional) 2.2.2.v201001271707-43799oB5855B7A2242
WST Server Adapters 3.1.0.v200906020451-51DFAkF77g7GCNc
Xpand SDK (Incubation) 0.7.2.v200908120436
XSD - XML Schema Definition SDK 2.5.0.v200906151043
Xtext SDK (Incubation) 0.7.2.v200908120607
05.05.10 15:38:09 MESZ:
Subversive SVN Integration for the Mylyn Project (Optional) (Incubation) 0.7.8.I20091023-1300
Subversive SVN Team Provider (Incubation) 0.7.8.I20091023-1300
05.05.10 09:05:01 MESZ:
04.05.10 15:23:09 MESZ
04.05.10 15:16:44 MESZ:
04.05.10 15:14:48 MESZ:
04.05.10 15:05:38 MESZ:
03.05.10 21:58:49 MESZ:
18.02.10 22:59:06 MEZ:
18.02.10 22:59:00 MEZ:
18.02.10 22:54:44 MEZ:
Configuration Details:
*** Date: Sonntag, 9. Mai 2010 13:20:34 Deutschland
*** Platform Details:
*** System properties:
awt.toolkit=sun.awt.windows.WToolkit
eclipse.application=org.eclipse.ui.ide.workbench
eclipse.commands=-os
win32
-ws
win32
-arch
x86
-showsplash
C:\eclipse\soa\galileo\eclipse\\plugins\org.eclipse.platform _3.3.202.v201002111343\splash.bmp
-launcher
C:\eclipse\soa\galileo\eclipse\eclipse.exe
-name
Eclipse
--launcher.library
C:\eclipse\soa\galileo\eclipse\plugins/org.eclipse.equinox.l auncher.win32.win32.x86_1.0.200.v20090519\eclipse_1206.dll
-startup
C:\eclipse\soa\galileo\eclipse\plugins/org.eclipse.equinox.l auncher_1.0.201.R35x_v20090715.jar
-product
org.eclipse.epp.package.soa.product
-vm
C:\Programme\Java\jre6\bin\client\jvm.dll
eclipse.home.location=file:/C:/eclipse/soa/galileo/eclipse/
eclipse.launcher=C:\eclipse\soa\galileo\eclipse\eclipse.exe
eclipse.p2.data.area=@config.dir/../p2/
eclipse.p2.profile=epp.package.soa
eclipse.product=org.eclipse.epp.package.soa.product
eclipse.startTime=1273403213671
eclipse.vm=C:\Programme\Java\jre6\bin\client\jvm.dll
eclipse.vmargs=-Dosgi.requiredJavaVersion=1.5
-Xms40m
-Xmx256m
-XX:MaxPermSize=256m
-Djava.class.path=C:\eclipse\soa\galileo\eclipse\plugins/org .eclipse.equinox.launcher_1.0.201.R35x_v20090715.jar
file.encoding=Cp1252
file.encoding.pkg=sun.io
file.separator=\
java.awt.graphicsenv=sun.awt.Win32GraphicsEnvironment
java.awt.printerjob=sun.awt.windows.WPrinterJob
java.class.path=C:\eclipse\soa\galileo\eclipse\plugins/org.e clipse.equinox.launcher_1.0.201.R35x_v20090715.jar
java.class.version=50.0
java.endorsed.dirs=C:\Programme\Java\jre6\lib\endorsed
java.ext.dirs=C:\Programme\Java\jre6\lib\ext;C:\WINDOWS\Sun\ Java\lib\ext
java.home=C:\Programme\Java\jre6
java.io.tmpdir=C:\DOKUME~1\pst\LOKALE~1\Temp\
java.library.path=C:\eclipse\soa\galileo\eclipse;.;C:\WINDOW S\Sun\Java\bin;C:\WINDOWS\system32;C:\WINDOWS;C:/Programme/J ava/jre6/bin/client;C:/Programme/Java/jre6/bin;C:\oraclexe\a pp\oracle\product\10.2.0\server\bin;C:\WINDOWS\system32;C:\W INDOWS;C:\WINDOWS\System32\Wbem;C:\Programme\ATI Technologies\ATI.ACE\Core-Static;C:\xampp\php;C:\Programme\Q uickTime\QTSystem\
java.runtime.name=Java(TM) SE Runtime Environment
java.runtime.version=1.6.0_20-b02
java.specification.name=Java Platform API Specification
java.specification.vendor=Sun Microsystems Inc.
java.specification.version=1.6
java.vendor.url=http://java.sun.com/
java.vendor.url.bug=http://java.sun.com/cgi-bin/bugreport.cgi
java.version=1.6.0_20
java.vm.info=mixed mode, sharing
java.vm.name=Java HotSpot(TM) Client VM
java.vm.specification.name=Java Virtual Machine Specification
java.vm.specification.vendor=Sun Microsystems Inc.
java.vm.specification.version=1.0
java.vm.vendor=Sun Microsystems Inc.
java.vm.version=16.3-b01
line.separator=
org.apache.commons.logging.Log=org.apache.commons.logging.im pl.NoOpLog
org.eclipse.debug.ui.breakpoints.toggleFactoriesUsed=true
org.eclipse.equinox.launcher.splash.location=C:\eclipse\soa\ galileo\eclipse\\plugins\org.eclipse.platform_3.3.202.v20100 2111343\splash.bmp
org.eclipse.equinox.simpleconfigurator.configUrl=file:org.ec lipse.equinox.simpleconfigurator/bundles.info
org.eclipse.update.reconcile=false
org.osgi.framework.executionenvironment=OSGi/Minimum-1.0,OSG i/Minimum-1.1,OSGi/Minimum-1.2,JRE-1.1,J2SE-1.2,J2SE-1.3,J2S E-1.4,J2SE-1.5,JavaSE-1.6
org.osgi.framework.language=de
org.osgi.framework.os.name=WindowsXP
org.osgi.framework.os.version=5.1.0
org.osgi.framework.processor=x86
org.osgi.framework.system.packages=javax.accessibility,javax .activation,javax.activity,javax.annotation,javax.annotation .processing,javax.crypto,javax.crypto.interfaces,javax.crypt o.spec,javax.imageio,javax.imageio.event,javax.imageio.metad ata,javax.imageio.plugins.bmp,javax.imageio.plugins.jpeg,jav ax.imageio.spi,javax.imageio.stream,javax.jws,javax.jws.soap ,javax.lang.model,javax.lang.model.element,javax.lang.model. type,javax.lang.model.util,javax.management,javax.management .loading,javax.management.modelmbean,javax.management.monito r,javax.management.openmbean,javax.management.relation,javax .management.remote,javax.management.remote.rmi,javax.managem ent.timer,javax.naming,javax.naming.directory,javax.naming.e vent,javax.naming.ldap,javax.naming.spi,javax.net,javax.net. ssl,javax.print,javax.print.attribute,javax.print.attribute. standard,javax.print.event,javax.rmi,javax.rmi.CORBA,javax.r mi.ssl,javax.script,javax.security.auth,javax.security.auth. callback,javax.security.auth.kerberos,javax.security.auth.lo gin,javax.security.auth.spi,javax.security.auth.x500,javax.s ecurity.cert,javax.security.sasl,javax.sound.midi,javax.soun d.midi.spi,javax.sound.sampled,javax.sound.sampled.spi,javax .sql,javax.sql.rowset,javax.sql.rowset.serial,javax.sql.rows et.spi,javax.swing,javax.swing.border,javax.swing.colorchoos er,javax.swing.event,javax.swing.filechooser,javax.swing.pla f,javax.swing.plaf.basic,javax.swing.plaf.metal,javax.swing. plaf.multi,javax.swing.plaf.synth,javax.swing.table,javax.sw ing.text,javax.swing.text.html,javax.swing.text.html.parser, javax.swing.text.rtf,javax.swing.tree,javax.swing.undo,javax .tools,javax.transaction,javax.transaction.xa,javax.xml,java x.xml.bind,javax.xml.bind.annotation,javax.xml.bind.annotati on.adapters,javax.xml.bind.attachment,javax.xml.bind.helpers ,javax.xml.bind.util,javax.xml.crypto,javax.xml.crypto.dom,j avax.xml.crypto.dsig,javax.xml.crypto.dsig.dom,javax.xml.cry pto.dsig.keyinfo,javax.xml.crypto.dsig.spec,javax.xml.dataty pe,javax.xml.namespace,javax.xml.parsers,javax.xml.soap,java x.xml.stream,javax.xml.stream.events,javax.xml.stream.util,j avax.xml.transform,javax.xml.transform.dom,javax.xml.transfo rm.sax,javax.xml.transform.stax,javax.xml.transform.stream,j avax.xml.validation,javax.xml.ws,javax.xml.ws.handler,javax. xml.ws.handler.soap,javax.xml.ws.http,javax.xml.ws.soap,java x.xml.ws.spi,javax.xml.ws.wsaddressing,javax.xml.xpath,org.i etf.jgss,org.omg.CORBA,org.omg.CORBA_2_3,org.omg.CORBA_2_3.p ortable,org.omg.CORBA.DynAnyPackage,org.omg.CORBA.ORBPackage ,org.omg.CORBA.portable,org.omg.CORBA.TypeCodePackage,org.om g.CosNaming,org.omg.CosNaming.NamingContextExtPackage,org.om g.CosNaming.NamingContextPackage,org.omg.Dynamic,org.omg.Dyn amicAny,org.omg.DynamicAny.DynAnyFactoryPackage,org.omg.Dyna micAny.DynAnyPackage,org.omg.IOP,org.omg.IOP.CodecFactoryPac kage,org.omg.IOP.CodecPackage,org.omg.Messaging,org.omg.Port ableInterceptor,org.omg.PortableInterceptor.ORBInitInfoPacka ge,org.omg.PortableServer,org.omg.PortableServer.CurrentPack age,org.omg.PortableServer.POAManagerPackage,org.omg.Portabl eServer.POAPackage,org.omg.PortableServer.portable,org.omg.P ortableServer.ServantLocatorPackage,org.omg.SendingContext,o rg.omg.stub.java.rmi,org.w3c.dom,org.w3c.dom.bootstrap,org.w 3c.dom.css,org.w3c.dom.events,org.w3c.dom.html,org.w3c.dom.l s,org.w3c.dom.ranges,org.w3c.dom.stylesheets,org.w3c.dom.tra versal,org.w3c.dom.views,org.w3c.dom.xpath,org.xml.sax,org.x ml.sax.ext,org.xml.sax.helpers
org.osgi.framework.vendor=Eclipse
org.osgi.framework.version=1.5.0
org.osgi.supports.framework.extension=true
org.osgi.supports.framework.fragment=true
org.osgi.supports.framework.requirebundle=true
os.arch=x86
os.name=Windows XP
os.version=5.1
osgi.arch=x86
osgi.bundles=reference:file:javax.transaction_1.1.1.v2010021 11330.jar,reference:file: org.eclipse.equinox.simpleconfigurator_1.0.101.R35x_v2009080 7-1100.jar @1:start
osgi.bundles.defaultStartLevel=4
osgi.bundlestore=C:\eclipse\soa\galileo\eclipse\configuratio n\org.eclipse.osgi\bundles
osgi.configuration.area=file:/C:/eclipse/soa/galileo/eclipse /configuration/
osgi.framework=file:/c:/eclipse/soa/galileo/eclipse/plugins/ org.eclipse.osgi_3.5.2.R35x_v20100126.jar
osgi.framework.extensions=reference:file:javax.transaction_1 .1.1.v201002111330.jar
osgi.framework.shape=jar
osgi.framework.version=3.5.2.R35x_v20100126
osgi.frameworkClassPath=., file:c:/eclipse/soa/galileo/eclipse/plugins/javax.transactio n_1.1.1.v201002111330.jar
osgi.install.area=file:/C:/eclipse/soa/galileo/eclipse/
osgi.instance.area=file:/C:/eclipse/soa/workspace/
osgi.instance.area.default=file:/C:/Dokumente und Einstellungen/pst/workspace/
osgi.logfile=C:\eclipse\soa\workspace\.metadata\.log
osgi.manifest.cache=C:\eclipse\soa\galileo\eclipse\configura tion\org.eclipse.osgi\manifests
osgi.nl=de_CH
osgi.os=win32
osgi.splashLocation=C:\eclipse\soa\galileo\eclipse\\plugins\ org.eclipse.platform_3.3.202.v201002111343\splash.bmp
osgi.splashPath=platform:/base/plugins/org.eclipse.platform
osgi.syspath=c:\eclipse\soa\galileo\eclipse\plugins
osgi.tracefile=C:\eclipse\soa\workspace\.metadata\trace.log
osgi.ws=win32
path.separator=;
sun.arch.data.model=32
sun.boot.class.path=C:\Programme\Java\jre6\lib\resources.jar ;C:\Programme\Java\jre6\lib\rt.jar;C:\Programme\Java\jre6\li b\sunrsasign.jar;C:\Programme\Java\jre6\lib\jsse.jar;C:\Prog ramme\Java\jre6\lib\jce.jar;C:\Programme\Java\jre6\lib\chars ets.jar;C:\Programme\Java\jre6\classes
sun.boot.library.path=C:\Programme\Java\jre6\bin
sun.cpu.endian=little
sun.cpu.isalist=pentium_pro+mmx pentium_pro pentium+mmx pentium i486 i386 i86
sun.desktop=windows
sun.io.unicode.encoding=UnicodeLittle
sun.jnu.encoding=Cp1252
sun.management.compiler=HotSpot Client Compiler
sun.os.patch.level=Service Pack 3
user.country=CH
user.dir=C:\eclipse\soa\galileo\eclipse
user.home=C:\Dokumente und Einstellungen\pst
user.language=de
user.name=pst
user.timezone=Europe/Berlin
user.variant=
*** Features:
org.eclipse.acceleo (0.8.1.v200909161003) "Acceleo"
org.eclipse.acceleo.doc (0.8.1.v200909161003) "Acceleo Documentation"
org.eclipse.acceleo.examples (0.8.1.v200909161003) "Acceleo Examples"
org.eclipse.acceleo.sdk (0.8.1.v200909161003) "Acceleo"
org.eclipse.acceleo.source (0.8.1.v200909161003) "Acceleo Runtime Source"
org.eclipse.acceleo.ui.capabilities (0.8.1.v200909161003) "Acceleo UI capability definitions"
org.eclipse.cdt (6.0.2.201002161416) "Eclipse C/C++ Development Tools"
org.eclipse.cdt.mylyn (5.1.0.201002161416) "Mylyn Bridge: C/C++ Development"
org.eclipse.cvs (1.1.101.R35x_v20100125-7E79FGD9kKF67BPDZ7PKCE1911) "Eclipse CVS Client"
org.eclipse.datatools.common.doc.user (1.7.2.v200909251450-26-311A16321A3557) "Data Tools Platform User Documentation"
org.eclipse.datatools.connectivity.doc.user (1.7.2.v200909251450-37D-7733L3D753L7BBF) "Data Tools Platform Connectivity User Documentation"
org.eclipse.datatools.connectivity.feature (1.7.2.v200909251450-7B7OANEn1Xi4gycmhPC6njFVDz0q) "Data Tools Platform Connectivity Plug-in"
org.eclipse.datatools.connectivity.oda.designer.feature (1.7.2.v200909251450-7E7C7BDZRDIVDUKiEaXU) "DTP ODA Designer UI Framework Plug-in"
org.eclipse.datatools.connectivity.oda.feature (1.7.2.v200909251450-7H797BCcNBHBBHMWDbRK) "DTP Open Data Access"
org.eclipse.datatools.doc.user (1.7.2.v200909251450-47C08w95ENAK6AFDFK7) "Data Tool Platform User Documentation"
org.eclipse.datatools.enablement.apache.derby.feature (1.7.2.v200909251450-7768dBmKDLfMjHuIFJW7SBI) "High-level Sybase Enablement Plug-in"
org.eclipse.datatools.enablement.feature (1.7.2.v200909251450-7J8i7UBWwSLRWdU50unZvFu_Pz0t) "Eclipse Data Tools Platform Enablement"
org.eclipse.datatools.enablement.hsqldb.feature (1.7.2.v200909251450-67B2AqGBJVKbGuH3GP7SBI) "Eclipse Data Tools Platform Enablement"
org.eclipse.datatools.enablement.ibm.feature (1.7.2.v200909251450-7F47HFC7sRTNSjXAYIRR) "Eclipse Data Tools Platform Enablement"
org.eclipse.datatools.enablement.ingres.feature (1.7.2.v200909251450-540AkF77g7VBLBPH7) "Eclipse Data Tools Platform Enablement"
org.eclipse.datatools.enablement.jdbc.feature (1.7.2.v200909251450-4-29oB55W5P7G6RAH) "High-level Sybase Enablement Plug-in"
org.eclipse.datatools.enablement.jdt.feature (1.7.2.v200909251450-2-07w311A1A351453) "Data Tools Platform Connectivity JDT Extension Plug-in"
org.eclipse.datatools.enablement.msft.feature (1.7.2.v200909251450-542AkF78Y7SBU9UAB) "Eclipse Data Tools Platform Enablement"
org.eclipse.datatools.enablement.mysql.feature (1.7.2.v200909251450-546AkF78Y7R9PAX87) "Eclipse Data Tools Platform Enablement"
org.eclipse.datatools.enablement.oda.designer.feature (1.7.2.v200909251450-3328s7353356I4F53) "Eclipse Data Tools Platform XML ODA Designer"
org.eclipse.datatools.enablement.oda.feature (1.7.2.v200909251450-7A7T78DZRDFuD_KmFcNp) "Eclipse Data Tools Platform XML ODA Runtime Driver"
org.eclipse.datatools.enablement.oracle.feature (1.7.2.v200909251450-548aAkF77g7XAO9aBB) "Eclipse Data Tools Platform Enablement"
org.eclipse.datatools.enablement.postgresql.feature (1.7.2.v200909251450-542AkF77g7V9N9e77) "Eclipse Data Tools Platform Enablement"
org.eclipse.datatools.enablement.sap.feature (1.7.2.v200909251450-540AkF77g7V9N9e77) "Eclipse Data Tools Platform Enablement"
org.eclipse.datatools.enablement.sdk.feature (1.7.2.v200909251450-7I8r7XFE9JfFs0wYgDsB0wKAZttV) "Eclipse Data Tools Platform Enablement"
org.eclipse.datatools.enablement.sqlite.feature (1.7.2.v200909251450-541AkF79P7N8NAQ97) "Eclipse Data Tools Platform Enablement"
org.eclipse.datatools.enablement.sybase.feature (1.7.2.v200909251450-7E45F9NiNWvOOXxPdVT) "High-level Sybase Enablement Plug-in"
org.eclipse.datatools.intro (1.7.2.v200909251450-26-7w311A17142212) "Eclipse Data Tools Platform Intro Plug-in"
org.eclipse.datatools.modelbase.feature (1.7.2.v200909251450-77-5CcNBCtCcCQJYZl) "Eclipse Data Tools Platform SQLModel Plug-in"
org.eclipse.datatools.sdk.feature (1.7.2.v200909251450-7O9I7bFD0IVIPElYvW1YBTgDFOgj) "DTP SDK Plug-in"
org.eclipse.datatools.sqldevtools.ddlgen.feature (1.7.2.v200909251450-7A-1F7RZHKFIwMhStRm) "Eclipse Data Tools Platform FE UI Plug-in"
org.eclipse.datatools.sqldevtools.feature (1.7.2.v200909251450-7N7q7GFDr_mX5M8JAs38u8wWDRWU) "Eclipse Data Tools Platform SQL Tools Common UI Plug-in"
org.eclipse.datatools.sqldevtools.parsers.feature (1.7.2.v200909251450-602BgJ99q9_9OGXFJ) "Eclipse Data Tools Platform SQL Parser Plugin"
org.eclipse.datatools.sqltools.doc.user (1.7.2.v200909251450-37D-7733L3D753L7BBF) "Data Tools Platform SQL Tools User Documentation"
org.eclipse.dltk.core (1.0.2.v20100208-7C-77EAAoORwQXXqBeY-d) "Eclipse Dynamic Languages Toolkit"
org.eclipse.dltk.itcl (1.0.0.v20090613-1432-3--9oA55V5L9K28LC_) "iTcl Extension Support for TCL language"
org.eclipse.dltk.mylyn (1.0.0.v20090610-1638-1--7w311_17261119) "Mylyn DLTK Bridge"
org.eclipse.dltk.ruby (1.0.0.v20090610-1638-7B--E_EkMO1PJYsAZIz-C) "Ruby Development Tools"
org.eclipse.dltk.tcl (1.0.1.v20090903-2153-7D-4EB7sQSMTibkCiTAc) "Tcl Development Tools"
org.eclipse.dltk.xotcl (1.0.0.v20090610-1638-4-0_kE77g7W_V29IEA) "XOTcl Extension Support for TCL language"
org.eclipse.draw2d (3.5.2.v20100111-1352-4417w311A223702A19) "Graphical Editing Framework Draw2d"
org.eclipse.ecf.core (3.0.1.v20090916-2238) "Eclipse Communication Framework (ECF)"
org.eclipse.emf (2.5.0.v200906151043) "EMF - Eclipse Modeling Framework Runtime and Tools"
org.eclipse.emf.cdo (2.0.0.v200906160459) "CDO Model Repository Client"
org.eclipse.emf.cdo.defs (2.0.0.v200906160459) "CDO Model Repository Definitions "
org.eclipse.emf.cdo.doc (2.0.0.v200906160459) "CDO Model Repository Documentation"
org.eclipse.emf.cdo.examples (2.0.0.v200906160459) "CDO Model Repository Examples"
org.eclipse.emf.cdo.server (2.0.0.v200906160459) "CDO Model Repository Server"
org.eclipse.emf.codegen (2.5.0.v200906151043) "EMF Code Generation"
org.eclipse.emf.codegen.ecore (2.5.0.v200906151043) "EMF Ecore Code Generator"
org.eclipse.emf.codegen.ecore.ui (2.5.0.v200906151043) "EMF Ecore Code Generator UI"
org.eclipse.emf.codegen.ui (2.4.0.v200906151043) "EMF Code Generation UI"
org.eclipse.emf.common (2.5.0.v200906151043) "EMF Common"
org.eclipse.emf.common.ui (2.5.0.v200906151043) "EMF Common UI"
org.eclipse.emf.compare (1.0.1.v200909161031) "EMF Compare core"
org.eclipse.emf.compare.doc (1.0.1.v200909161031) "EMF Compare Documentation"
org.eclipse.emf.compare.sdk (1.0.1.v200909161031) "EMF Compare core"
org.eclipse.emf.compare.source (1.0.1.v200909161031) "EMF Compare Source"
org.eclipse.emf.converter (2.5.0.v200906151043) "EMF Model Converter"
org.eclipse.emf.databinding (1.1.0.v200906151043) "EMF Data Binding"
org.eclipse.emf.databinding.edit (1.1.0.v200906151043) "EMF Edit Data Binding"
org.eclipse.emf.doc (2.5.0.v200906151043) "EMF Documentation"
org.eclipse.emf.ecore (2.5.0.v200906151043) "EMF Ecore"
org.eclipse.emf.ecore.edit (2.5.0.v200906151043) "EMF Ecore Edit"
org.eclipse.emf.ecore.editor (2.5.0.v200906151043) "EMF Sample Ecore Editor"
org.eclipse.emf.ecoretools (0.9.0.v200906221231) "Ecore Tools (Incubation)"
org.eclipse.emf.ecoretools.doc (0.8.0.v200906221231) "Ecore Tools Documentation (Incubation)"
org.eclipse.emf.ecoretools.source (0.9.0.v200906221231) "Ecore Tools Source (Incubation)"
org.eclipse.emf.edit (2.5.0.v200906151043) "EMF Edit"
org.eclipse.emf.edit.ui (2.5.0.v200906151043) "EMF Edit UI"
org.eclipse.emf.index.source (0.7.0.v200908120607) "EMF Index Source (Incubation)"
org.eclipse.emf.mapping (2.5.0.v200906151043) "EMF Mapping"
org.eclipse.emf.mapping.ecore (2.5.0.v200906151043) "EMF Ecore Mapping"
org.eclipse.emf.mapping.ecore.editor (2.5.0.v200906151043) "EMF Ecore Mapping Editor"
org.eclipse.emf.mapping.ui (2.5.0.v200906151043) "EMF Mapping UI"
org.eclipse.emf.mint (0.8.0.v200906161513) "Mint Runtime (Incubation)"
org.eclipse.emf.mint.doc (0.8.0.v200906161513) "Mint Developer Guide (Incubation)"
org.eclipse.emf.mwe.core (0.7.2.v200908120417) "MWE Core (Incubation)"
org.eclipse.emf.mwe.core.source (0.7.2.v200908120417) "MWE Core Source (Incubation)"
org.eclipse.emf.mwe.doc (0.7.2.v200908120417) "MWE Documentation (Incubation)"
org.eclipse.emf.mwe.examples (0.7.2.v200908120417) "MWE Examples (Incubation)"
org.eclipse.emf.mwe.examples.source (0.7.2.v200908120417) "MWE Examples Source (Incubation)"
org.eclipse.emf.mwe.ui (0.7.2.v200908120417) "MWE UI (Incubation)"
org.eclipse.emf.mwe.ui.source (0.7.2.v200908120417) "MWE Core UI Source (Incubation)"
org.eclipse.emf.ocl (1.1.101.v200901271800-208_7w311A12382911) "Object Constraint Language (OCL) 2.0 Compatibility API"
org.eclipse.emf.ocl.doc (1.2.1.v200901271800-208_7w311A17262341) "Object Constraint Language (OCL) 2.0 Compatibility API Documentation"
org.eclipse.emf.query (1.2.100.v200901271643-218Z7w311A142A1142) "EMF Model Query"
org.eclipse.emf.query.doc (1.2.100.v200901271543-33-8s733L357H5FB9) "EMF Model Query Documentation"
org.eclipse.emf.query.ocl (1.2.100.v200901271643-21-7w311A142A1142) "EMF Model Query OCL Integration"
org.eclipse.emf.teneo (1.1.1.v200909151729-7862DZRDEBEBKlKz-SB) "EMF Teneo"
org.eclipse.emf.teneo.doc (1.1.0.v200909151729-20-7w311A1A26283A) "EMF Teneo Documentation"
org.eclipse.emf.teneo.eclipselink (1.1.1.v200909151729-7910EVVFGMGMNsO6WM) "EMF Teneo EclipseLink Plug-in"
org.eclipse.emf.transaction (1.3.1.v20090819-1457-3508s733L3D4D26998) "EMF Model Transaction Core"
org.eclipse.emf.transaction.doc (1.3.0.v200901271819-348Z8s733L357H5J5L) "EMF Model Transaction Documentation"
org.eclipse.emf.validation (1.3.0.v200902052232-478-9oB55W58BQ8QBB) "EMF Validation Framework Core"
org.eclipse.emf.validation.doc (1.3.0.v200901271722-35-8s733L357H5H77) "EMF Validation Framework Documentation"
org.eclipse.emf.validation.ocl (1.2.0.v200901271722-22-7w311A12382833) "EMF Validation Framework OCL Integration"
org.eclipse.emf.workspace (1.3.0.v200901271819-35-8s733L366A4F6E) "EMF Model Transaction Workbench Integration Core"
org.eclipse.emf.workspace.doc (1.3.0.v200901271819-22-7w311A1238292A) "EMF Model Transaction Workbench Integration Documentation"
org.eclipse.epp.package.soa.feature (1.2.2.20100216-1730) "EPP SOA Bundle"
org.eclipse.gef (3.5.2.v20100111-1352-777928194B66D5D476C33B2A) "Graphical Editing Framework GEF"
org.eclipse.gmf (1.3.0.v20091021-2333-7d8W3FXwnL5Tg7CuwHV2mGBrQk0b) "Graphical Modeling Framework"
org.eclipse.gmf.doc (1.3.0.v20090729-2029-35-8s733L3H7L1737L) "Graphical Modeling Framework Documentation"
org.eclipse.gmf.examples.pde (1.2.0.v20090114-0940-318Z8s733L3D4B14H53) "Graphical Modeling Framework Examples"
org.eclipse.gmf.runtime.notation (1.3.0.v20100113-1121-33-8s733L537517999) "GMF Notation Model Support"
org.eclipse.gmf.sdk (2.2.2.v20100209-2200-7C7I-BLxlyz-uojrqeOfnk4eytKd) "Graphical Modeling Framework SDK"
org.eclipse.gmf.tooling (2.2.0.v20090317-0630-7c7GFBXFLWUko2mHECQ9Cfd) "Graphical Modeling Framework Tooling"
org.eclipse.help (1.1.2.R35x_v20100119-7e7eFAnFEx2X_fZltJhDjz-D) "Help System Base"
org.eclipse.jdt (3.5.2.r352_v20100108-7r88FEwFI0WTuoBl0iaG0tyhfZH6) "Eclipse Java Development Tools"
org.eclipse.jet (1.0.2.v201001281539-508cAkF78Y7VCLASCK) "Java Emitter Templates (JET)"
org.eclipse.jet.doc (1.0.2.v201001281539-2-17w31211239264A) "Java Emitter Templates (JET) Documentation"
org.eclipse.jet.source (1.0.2.v201001281539) "Eclipse Model to Text - JET SDK"
org.eclipse.jpt.eclipselink.feature (2.2.2.v200911250220-65A9AkF77g8OFL7BB7) "Dali Java Persistence Tools - EclipseLink Support"
org.eclipse.jpt.feature (2.2.2.v200911250220-7L7OAPFBBoPS0TBgXV1je) "Dali Java Persistence Tools"
org.eclipse.jst.common.fproj.enablement.jdt (3.1.1.v200908111817-37718s733L56485K8H) "Eclipse Faceted Project Framework JDT Enablement"
org.eclipse.jst.enterprise_ui.feature (3.1.1.v200908101600-7_7EGrjFQRwRb4P511ebObS5XZhq) "Eclipse Java EE Developer Tools"
org.eclipse.jst.ws.axis2tools.feature (1.1.0.v200905242110-78-FBpDZRDE6FdPdLYYe) "Axis2 Tools"
org.eclipse.m2m.atl (3.0.2.v201001190421) "ATL - ATLAS Transformation Language"
org.eclipse.m2m.atl.doc (3.0.2.v201001190421) "ATL Documentation"
org.eclipse.m2m.atl.examples (3.0.2.v201001190421) "ATL Examples"
org.eclipse.m2m.atl.source (3.0.2.v201001190421) "ATL Source"
org.eclipse.m2m.qvt.oml (2.0.1.v20090722-1630-78-0AkF77g7VCP3B_OE) "QVT Operational Compiler and Interpreter"
org.eclipse.m2m.qvt.oml.common (2.0.1.v20090722-1630-79-0AkF77g7UDT3BcL7) "QVT Operational Common"
org.eclipse.m2m.qvt.oml.doc (2.0.0.v20090316-1930-3--7w311A172702611) "QVT Operational Documentation"
org.eclipse.m2m.qvt.oml.editor (2.0.1.v20090701-2200-3-07w311A181203311) "QVT Operational Editor"
org.eclipse.m2m.qvt.oml.examples (2.0.0.v20090616-1500-3--7w311A171902941) "QVT Operational Samples"
org.eclipse.m2m.qvt.oml.runtime (2.0.0.v20090410-1820-79--AkF77g7RCR3BeK7) "QVT Operational Runtime"
org.eclipse.m2m.qvt.oml.sdk (2.0.1.v20090701-2200-7N-5CLrGiFfYqKJ7FOaWVaJlXLqT) "QVT Operational Compiler and Interpreter"
org.eclipse.mylyn_feature (3.2.3.v20100217-0100-e3x) "Mylyn"
org.eclipse.mylyn.bugzilla_feature (3.2.3.v20100217-0100-e3x) "Mylyn"
org.eclipse.mylyn.context_feature (3.2.3.v20100217-0100-e3x) "Mylyn"
org.eclipse.mylyn.ide_feature (3.2.3.v20100217-0100-e3x) "Mylyn"
org.eclipse.mylyn.java_feature (3.2.3.v20100217-0100-e3x) "Mylyn"
org.eclipse.mylyn.pde_feature (3.2.3.v20100217-0100-e3x) "Mylyn"
org.eclipse.mylyn.sdk_feature (3.2.3.v20100217-0100-e3x) "Mylyn"
org.eclipse.mylyn.team_feature (3.2.3.v20100217-0100-e3x) "Mylyn"
org.eclipse.mylyn.wikitext_feature (1.1.3.v20100217-0100-e3x) "Mylyn"
org.eclipse.net4j (2.0.0.v200906160348) "Net4j Signalling Platform Runtime"
org.eclipse.net4j.db (2.0.0.v200906160348) "Net4j DB Framework"
org.eclipse.net4j.defs (2.0.0.v200906160348) "Net4j Signalling Platform Definitions"
org.eclipse.net4j.doc (2.0.0.v200906160348) "Net4j Signalling Platform Documentation"
org.eclipse.net4j.examples (2.0.0.v200906160348) "Net4j Signalling Platform Examples"
org.eclipse.net4j.ui (2.0.0.v200906160348) "Net4j Signalling Platform UI"
org.eclipse.ocl (1.3.0.v200901271800-46-9oB55V5I9P8M65) "Object Constraint Language (OCL) 2.0 Parser/Interpreter"
org.eclipse.ocl.doc (1.3.0.v200901271800-35-8s733L3A6F5D63) "Object Constraint Language (OCL) 2.0 Documentation"
org.eclipse.ocl.uml (2.0.0.v200901271800-3--7w311A16382511) "OCL 2.0 Binding for UML"
org.eclipse.pde (3.5.2.R35x_v20100119-7Z7_FA2FDX-aXQYWqYDBz-z0qufo) "PDE"
org.eclipse.php (2.1.3.v20090914-1400-7L7979F8NcJKhKWS09TTK2) "PDT Plug-in"
org.eclipse.php.source (2.1.3.v20090914-1400-7L7979F8NcJKhKWS09TTK2) "pluginName"
org.eclipse.platform (3.5.2.R35x_v20100210-0800-9hEiFzmFst-TiEn9hNYgDWg1XN8ulH_Jv CNGB) "Eclipse Platform"
org.eclipse.rcp (3.5.2.R35x_v20100119-9SA0FxwFnoCU5XxWItFdXXb27BA6) "Eclipse RCP"
org.eclipse.stp.branding.feature (2.0.1.200909171139) "SOA Tools Platform"
org.eclipse.uml2 (3.0.1.v200908281330) "UML2"
org.eclipse.uml2.diagram (0.9.0.v200906190654) "UML2 Diagramming Plug-in (Incubation)"
org.eclipse.uml2.doc (3.0.0.v200908281330) "UML2 Documentation"
org.eclipse.uml2.examples (3.0.0.v200905041045) "UML2 Examples"
org.eclipse.uml2tools (0.9.0.v200906190654) "UML2 Tools Plug-in (Incubation)"
org.eclipse.wst.common.fproj (3.1.1.v200908111817-37718s733L4C585I7F) "Eclipse Faceted Project Framework"
org.eclipse.wst.jsdt.feature (1.1.2.v200908101420-77-FGDCcNBDjBXMoBbFb) "JavaScript Developer Tools "
org.eclipse.wst.web_ui.feature (3.1.1.v200908120400-7R77FStEVw2z07WtDz-OZrhL5C-3) "Eclipse Web Developer Tools"
org.eclipse.wst.xml_ui.feature (3.1.1.v200907161031-7H6FMbDxtkMs9OeLGF98LRhdPKeo) "Eclipse XML Editors and Tools"
org.eclipse.wst.xsl.feature (1.0.2.v200908271520-7R7T8sFIhIehWg454rq_U1) "Eclipse XSL Developer Tools"
org.eclipse.xpand (0.7.2.v200908120436) "Xpand core (Incubation)"
org.eclipse.xpand.doc (0.7.2.v200908120436) "M2T Xpand Documentation (Incubation)"
org.eclipse.xpand.examples (0.7.2.v200908120436) "Xpand Examples (Incubation)"
org.eclipse.xpand.examples.source (0.7.2.v200908120436) "Xpand SDK (Incubation)"
org.eclipse.xpand.source (0.7.2.v200908120436) "Xpand SDK (Incubation)"
org.eclipse.xpand.ui (0.7.2.v200908120436) "Xpand editor (Incubation)"
org.eclipse.xpand.ui.source (0.7.2.v200908120436) "Xpand UI Developer Resources (Incubation)"
org.eclipse.xsd (2.5.0.v200906151043) "XSD Model"
org.eclipse.xsd.doc (2.5.0.v200906151043) "XSD Documentation"
org.eclipse.xsd.ecore.converter (2.5.0.v200906151043) "XSD Ecore Converter"
org.eclipse.xsd.edit (2.5.0.v200906151043) "XSD Edit"
org.eclipse.xsd.editor (2.5.0.v200906151043) "XSD Sample Editor"
org.eclipse.xsd.mapping (2.5.0.v200906151043) "XSD Mapping"
org.eclipse.xsd.mapping.editor (2.5.0.v200906151043) "XSD Mapping Editor"
org.eclipse.xtend (0.7.2.v200908120436) "Xtend core (Incubation)"
org.eclipse.xtend.source (0.7.2.v200908120436) "Xtend Source (Incubation)"
org.eclipse.xtend.typesystem.emf (0.7.0.v200908120436) "Xtend emf typesystem (Incubation)"
org.eclipse.xtend.typesystem.emf.source (0.7.0.v200908120436) "Xtend EMF typesystem Source (Incubation)"
org.eclipse.xtend.typesystem.uml2 (0.7.2.v200908120436) "Xtend UML2 typesystem (Incubation)"
org.eclipse.xtend.typesystem.uml2.source (0.7.2.v200908120436) "Xtend UML2 typesystem Source (Incubation)"
org.eclipse.xtend.typesystem.xsd (0.7.2.v200908120436) "Xtend XSD typesystem (Incubation)"
org.eclipse.xtend.typesystem.xsd.source (0.7.2.v200908120436) "Xtend XSD typesystem Source (Incubation)"
org.eclipse.xtend.ui (0.7.2.v200908120436) "Xtend UI (Incubation)"
org.eclipse.xtend.ui.source (0.7.2.v200908120436) "Xtend UI Developer Resources (Incubation)"
org.eclipse.xtext.docs (0.7.2.v200908120607) "Xtext Documentation (Incubation)"
org.eclipse.xtext.examples.source (0.7.2.v200908120607) "Xtext Examples Source (Incubation)"
org.eclipse.xtext.runtime.source (0.7.2.v200908120607) "Xtext Runtime Source (Incubation)"
org.eclipse.xtext.sdk (0.7.2.v200908120607) "Xtext (Incubation)"
org.eclipse.xtext.sdk.source (0.7.2.v200908120607) "Xtext SDK Source (Incubation)"
org.eclipse.xtext.ui.source (0.7.2.v200908120607) "Xtext UI Source (Incubation)"
*** Plug-in Registry:
ch.ethz.iks.r_osgi.remote (1.0.0.RC4_v20090916-2238) "R_OSGi Remote Service" [Active]
ch.ethz.iks.slp (1.1.0.v20090916-2238) "jslp-osgi" [Active]
com.ctc.wstx (3.2.8.v201002111330) "com.ctc.wstx" [Resolved]
com.google.collect (0.8.0.v200908120607) "bundleName" [Resolved]
com.google.guice (1.0.1.v200908120607) "Guice Plug-in" [Resolved]
com.ibm.icu (4.0.1.v20090822) "International Components for Unicode for Java (ICU4J)" [Active]
com.jcraft.jsch (0.1.41.v200903070017) "JSch" [Resolved]
com.sun.xml.bind (2.1.12.v201002111330) "Java Architecture for XML Binding (JAXB) Implementation Plug-in" [Resolved]
java_cup.runtime (0.10.0.v200803061811) "Java Cup" [Resolved]
javax.activation (1.1.0.v200906290531) "Apache Geronimo Activation Plug-in" [Resolved]
javax.annotation (1.1.1.v201002111330) "geronimo jta 1.1 spec" [Resolved]
javax.jbi (1.2.0.v201002111330) "javax.jbi 1.2.0" [Resolved]
javax.jws (2.0.0.v200905261939) "Web Services Metadata" [Resolved]
javax.mail (1.4.0.v200905040518) "Javax Mail Plug-in" [Resolved]
javax.persistence (1.99.0.v200906021518) "JPA 1.0 - Extended for OSGi (1.99)" [Resolved]
javax.servlet (2.5.0.v200806031605) "Servlet API Bundle" [Resolved]
javax.servlet.jsp (2.0.0.v200806031607) "Java Server Pages API Bundle" [Resolved]
javax.transaction (1.1.1.v201002111330) "geronimo annotation 1.0 spec" [Resolved]
javax.wsdl (1.5.1.v200806030408) "WSDL4J" [Resolved]
javax.wsdl (1.6.2.v200806030405) "WSDL4J" [Resolved]
javax.xml (1.3.4.v200902170245) "JAXP XML" [Resolved]
javax.xml.bind (2.1.9.v200905050702) "XML Binding for Java" [Resolved]
javax.xml.bind.swordfish.tooling (0.9.2.v201002111330) "Tooling" [Resolved]
javax.xml.rpc (1.1.0.v200905122109) "JAX-RPC" [Resolved]
javax.xml.soap (1.3.0.v200904281458) "Java SOAP API" [Resolved]
javax.xml.soap (1.2.0.v200905122109) "SAAJ" [Resolved]
javax.xml.stream (1.0.1.v201001131653) "Java XML Streaming API" [Resolved]
javax.xml.stream.swordfish.tooling (0.9.2.v201002111330) "Tooling" [Resolved]
javax.xml.ws (2.1.0.v200902101523) "Bundle-Name.0" [Resolved]
net.sourceforge.lpg.lpgjavaruntime (1.1.0.v200803061910) "SourceForge LPG" [Resolved]
org.antlr.runtime (3.0.0.v200803061811) "ANTLR Runtime" [Resolved]
org.antlr.runtime (3.0.0.v200908120607) "ANTLR Runtime" [Resolved]
org.aopalliance (1.0.0.v200905130917) "Aopalliance Plug-in" [Resolved]
org.apache.ant (1.7.1.v20090120-1145) "Apache Ant" [Resolved]
org.apache.axiom (1.2.4.v201002111330) "Apache Axis2 Axiom Object Model" [Resolved]
org.apache.axis (1.4.0.v200905122109) "Apache Web Services" [Resolved]
org.apache.batik.bridge (1.6.0.v200805290154) "Apache Batik Bridge/GVT/Scripting" [Resolved]
org.apache.batik.css (1.6.0.v200805290154) "Apache Batik CSS" [Resolved]
org.apache.batik.dom (1.6.0.v200805290154) "Apache Batik DOM" [Resolved]
org.apache.batik.dom.svg (1.6.0.v200805290154) "Apache Batik SVG DOM" [Resolved]
org.apache.batik.ext.awt (1.6.0.v200805290154) "Apache Batik AWT Utilities" [Resolved]
org.apache.batik.parser (1.6.0.v200805290154) "Apache Batik Parser" [Resolved]
org.apache.batik.pdf (1.6.0.v200806031500) "Apache Batik PDF" [Resolved]
org.apache.batik.svggen (1.6.0.v200805290154) "Apache Batik SVG Generation" [Resolved]
org.apache.batik.transcoder (1.6.0.v200805290154) "Apache Batik Transcoder" [Resolved]
org.apache.batik.util (1.6.0.v200805290154) "Apache Batik Utilities" [Resolved]
org.apache.batik.util.gui (1.6.0.v200805290154) "Apache Batik GUI Utilities" [Resolved]
org.apache.batik.xml (1.6.0.v200805290154) "Apache Batik XML" [Resolved]
org.apache.bcel (5.2.0.v200803061811) "Apache BCEL" [Resolved]
org.apache.commons.cli (1.0.0.v20080604-1500) "pluginName" [Resolved]
org.apache.commons.codec (1.3.0.v20080530-1600) "Apache Commons Codec Plug-in" [Resolved]
org.apache.commons.codec (1.3.0.v20100106-1700) "Apache Commons Codec Plug-in" [Resolved]
org.apache.commons.collections (3.2.0.v200803061811) "Apache Commons Collections" [Resolved]
org.apache.commons.discovery (0.2.0.v200905122109) "Jakarta-Commons Discovery" [Resolved]
org.apache.commons.el (1.0.0.v200806031608) "Apache Commons JSP 2.0 Expression Language Interpreter" [Resolved]
org.apache.commons.httpclient (3.1.0.v20080605-1935) "Apache Commons Httpclient" [Resolved]
org.apache.commons.jxpath (1.2.0.v20080604-1500) "Apache Commons JXPath" [Resolved]
org.apache.commons.lang (2.3.0.v200803061910) "Apache Jakarta Commons Lang" [Resolved]
org.apache.commons.lang (2.4.0.v20081016-1030) "Apache Jakarta Commons Lang" [Resolved]
org.apache.commons.lang (2.1.0.v200803061811) "Apache Jakarta Commons Lang" [Resolved]
org.apache.commons.logging (1.0.4.v200904062259) "Apache Commons Logging Plug-in" [Resolved]
org.apache.commons.logging (1.1.1.v200904062255) "Apache Commons Logging Plug-in" [Resolved]
org.apache.cxf (2.1.3.v201002111330) "org.apache.cxf 2.1.3" [Resolved]
org.apache.cxf.binding.jbi (2.1.3.v201002111330) "org.apache.cxf.binding.jbi 2.1.3" [Resolved]
org.apache.cxf.transport.jbi (2.1.3.v201002111330) "org.apache.cxf.transport.jbi 2.1.3" [Resolved]
org.apache.derby (10.1.2.1_v200803061811) "Apache Derby Plug-in" [Resolved]
org.apache.jasper (5.5.17.v200903231320) "Apache Jasper 2 Plug-in" [Resolved]
org.apache.log4j (1.2.13.v200903072027) "Apache Jakarta log4j Plug-in" [Resolved]
org.apache.lucene (1.9.1.v20080530-1600) "Apache Lucene" [Resolved]
org.apache.lucene.analysis (1.9.1.v20080530-1600) "Apache Lucene Analysis" [Resolved]
org.apache.neethi (2.0.4.1) "Apache ServiceMix Bundles: neethi-2.0.4" [Resolved]
org.apache.oro (2.0.8.v200903061218) "Apache Jakarta ORO" [Resolved]
org.apache.servicemix.common (2009.1.0.v201002111330) "org.apache.servicemix.common" [Resolved]
org.apache.servicemix.cxf.binding.nmr (4.0.0.v201002111330) "org.apache.servicemix.cxf.binding.nmr 4.0.0" [Resolved]
org.apache.servicemix.cxf.transport.nmr (4.0.0.v201002111330) "org.apache.servicemix.cxf.transport.nmr 4.0.0" [Resolved]
org.apache.servicemix.cxf.transport.osgi (4.0.0.v201002111330) "org.apache.servicemix.cxf.transport.osgi 4.0.0" [Resolved]
org.apache.servicemix.document (1.0.0.v201002111330) "org.apache.servicemix.document 1.0.0" [Resolved]
org.apache.servicemix.http (2009.1.0.v201002111330) "org.apache.servicemix.http" [Resolved]
org.apache.servicemix.jbi.deployer (1.0.0.v201002111330) "org.apache.servicemix.jbi.deployer 1.0.0" [Resolved]
org.apache.servicemix.jbi.osgi (1.0.0.v201002111330) "org.apache.servicemix.jbi.osgi 1.0.0" [Resolved]
org.apache.servicemix.jbi.runtime (1.0.0.v201002111330) "org.apache.servicemix.jbi.runtime 1.0.0" [Resolved]
org.apache.servicemix.kernel.filemonitor (1.1.0.v201002111330) "org.apache.servicemix.kernel.filemonitor 1.1.0" [Resolved]
org.apache.servicemix.kernel.jaas.boot (1.1.0.v201002111330) "org.apache.servicemix.kernel.jaas.boot 1.1.0" [Resolved]
org.apache.servicemix.kernel.jaas.config (1.1.0.v201002111330) "org.apache.servicemix.kernel.jaas.config 1.1.0" [Resolved]
org.apache.servicemix.kernel.jaas.modules (1.1.0.v201002111330) "org.apache.servicemix.kernel.jaas.modules 1.1.0" [Resolved]
org.apache.servicemix.kernel.management (1.1.0.v201002111330) "org.apache.servicemix.kernel.management 1.1.0" [Resolved]
org.apache.servicemix.nmr.api (1.0.0.v201002111330) "org.apache.servicemix.nmr.api 1.0.0" [Resolved]
org.apache.servicemix.nmr.core (1.0.0.v201002111330) "org.apache.servicemix.nmr.core 1.0.0" [Resolved]
org.apache.servicemix.nmr.management (1.0.0.v201002111330) "org.apache.servicemix.nmr.management 1.0.0" [Resolved]
org.apache.servicemix.nmr.osgi (1.0.0.v201002111330) "org.apache.servicemix.nmr.osgi 1.0.0" [Resolved]
org.apache.servicemix.nmr.spring (1.0.0.v201002111330) "org.apache.servicemix.nmr.spring 1.0.0" [Resolved]
org.apache.servicemix.soap (2009.1.0.v201002111330) "org.apache.servicemix.soap" [Resolved]
org.apache.servicemix.soap2 (2009.1.0.v201002111330) "org.apache.servicemix.soap2" [Resolved]
org.apache.servicemix.utils (1.1.0.v201002111330) "servicemix-utils 1.1.0" [Resolved]
org.apache.velocity (1.5.0.v200905192330) "Apache Velocity Plug-in" [Resolved]
org.apache.velocity.swordfish.tooling (0.9.2.v201002111330) "Tooling" [Resolved]
org.apache.ws.commons.schema (1.4.2.v200905291151) "Bundle-Name.0" [Resolved]
org.apache.wsil4j (1.0.0.v200901211807) "WSIL4J" [Resolved]
org.apache.xalan (2.7.1.v200905122109) "Xalan-Java" [Resolved]
org.apache.xbean.classloader (3.5.0.v201002111330) "org.apache.xbean.classloader" [Resolved]
org.apache.xbean.spring (3.5.0.v201002111330) "org.apache.xbean.spring" [Resolved]
org.apache.xerces (2.9.0.v200909240008) "Apache Xerces-J" [Resolved]
org.apache.xml.resolver (1.2.0.v200902170519) "Apache XmlResolver" [Resolved]
org.apache.xml.serializer (2.7.1.v200902170519) "Apache XML Commons Serializer" [Resolved]
org.eclipse.acceleo.common (0.8.1.v200909161003) "Acceleo" [Starting]
org.eclipse.acceleo.doc (0.8.1.v200909161003) "Acceleo Documentation" [Starting]
org.eclipse.acceleo.engine (0.8.1.v200909161003) "Acceleo evaluation engine" [Starting]
org.eclipse.acceleo.examples (0.8.1.v200909161003) "Acceleo Examples" [Starting]
org.eclipse.acceleo.ide.ui (0.8.1.v200909161003) "Acceleo Eclipse User Interface" [Starting]
org.eclipse.acceleo.model (0.8.1.v200909161003) "Acceleo Model" [Starting]
org.eclipse.acceleo.parser (0.8.1.v200909161003) "Acceleo Parser" [Starting]
org.eclipse.acceleo.source (0.8.1.v200909161003) "Acceleo Runtime Source" [Resolved]
org.eclipse.acceleo.ui.capabilities (0.8.1.v200909161003) "Acceleo UI capability definitions" [Resolved]
org.eclipse.ant.core (3.2.101.v20091110_r352) "Ant Build Tool Core" [Starting]
org.eclipse.ant.ui (3.4.2.v20091204_r352) "Ant UI" [Starting]
org.eclipse.bpel.apache.ode.deploy.model (0.4.0) "ODE Deploy Descriptor EMF Model" [Starting]
org.eclipse.bpel.apache.ode.deploy.ui (0.4.0) "ODE Deploy Descriptor UI Plug-in" [Starting]
org.eclipse.bpel.apache.ode.runtime (0.4.0) "Apache ODE Runtime Plug-in" [Starting]
org.eclipse.bpel.common.model (0.4.0) "Extension Model (Incubation)" [Starting]
org.eclipse.bpel.common.ui (0.4.0) "Common UI (Incubation)" [Starting]
org.eclipse.bpel.model (0.4.0) "BPEL Model (Incubation)" [Starting]
org.eclipse.bpel.runtimes (0.4.0) "Eclipse BPEL Designer Runtimes" [Starting]
org.eclipse.bpel.ui (0.4.0) "BPEL Editor (Incubation)" [Starting]
org.eclipse.bpel.wsil.model (0.4.0) "WSIL Model (Incubation)" [Starting]
org.eclipse.cdt (6.0.2.201002161416) "Eclipse C/C++ Development Tools" [Starting]
org.eclipse.cdt.core (5.1.2.201002161416) "C/C++ Development Tools Core" [Starting]
org.eclipse.cdt.core.win32 (5.1.0.201002161416) "C/C++ Development Tools Core for Windows" [Resolved]
org.eclipse.cdt.debug.core (6.0.0.201002161416) "C/C++ Development Tools Debug Model" [Starting]
org.eclipse.cdt.debug.mi.core (6.0.0.201002161416) "C/C++ Development Tools GDB/MI CDI Debugger Core" [Starting]
org.eclipse.cdt.debug.mi.ui (6.0.0.201002161416) "C/C++ Development Tools GDB/MI CDI Debugger UI" [Starting]
org.eclipse.cdt.debug.ui (6.0.0.201002161416) "C/C++ Development Tools Debugger UI" [Starting]
org.eclipse.cdt.doc.user (5.1.0.201002161416) "C/C++ Development User Guide" [Starting]
org.eclipse.cdt.dsf (2.0.0.201002161416) "Debug Services Framework Core" [Starting]
org.eclipse.cdt.dsf.gdb (2.0.0.201002161416) "GDB DSF Debugger Integration Core" [Starting]
org.eclipse.cdt.dsf.gdb.ui (2.0.0.201002161416) "GDB DSF Debugger Integration UI" [Starting]
org.eclipse.cdt.dsf.ui (2.0.1.201002161416) "Debugger Services Framework UI" [Starting]
org.eclipse.cdt.launch (6.0.0.201002161416) "C/C++ Development Tools Launching Support" [Starting]
org.eclipse.cdt.make.core (6.0.0.201002161416) "C/C++ Standard make Build Core" [Starting]
org.eclipse.cdt.make.ui (6.0.1.201002161416) "C/C++ Standard make Build UI" [Starting]
org.eclipse.cdt.managedbuilder.core (6.0.0.201002161416) "CDT Build System Core" [Starting]
org.eclipse.cdt.managedbuilder.gnu.ui (5.0.100.201002161416) "GNU Managed Build Definitions" [Starting]
org.eclipse.cdt.managedbuilder.ui (5.1.0.201002161416) "C/C++ Managed Builder UI" [Starting]
org.eclipse.cdt.mylyn (1.0.100.201002161416) "Mylyn Bridge: C/C++ Development" [Resolved]
org.eclipse.cdt.mylyn.ui (1.0.100.201002161416) "Mylyn Bridge: C/C++ Development" [Starting]
org.eclipse.cdt.ui (5.1.2.201002161416) "C/C++ Development Tools UI" [Starting]
org.eclipse.compare (3.5.2.r35x_20100113-0800) "Compare Support" [Starting]
org.eclipse.compare.core (3.5.0.I20090430-0408) "Core Compare Support" [Active]
org.eclipse.compare.win32 (1.0.0.I20090430-0408) "Compare Support for Word" [Starting]
org.eclipse.core.boot (3.1.100.v20080218) "Core Boot" [Starting]
org.eclipse.core.commands (3.5.0.I20090525-2000) "Commands" [Resolved]
org.eclipse.core.contenttype (3.4.1.R35x_v20090826-0451) "Eclipse Content Mechanism" [Active]
org.eclipse.core.databinding (1.2.0.M20090819-0800) "JFace Data Binding" [Starting]
org.eclipse.core.databinding.beans (1.2.0.I20090525-2000) "JFace D
Re: Failed to create web services using swordfish tooling UI [message #532756 is a reply to message #532379] Tue, 11 May 2010 03:29 Go to previous messageGo to next message
Member
Cool WOW ...
Thanks a lot. I'll try to dig into this asap ...
icon14.gif  Re: Failed to create web services using swordfish tooling UI [message #555686 is a reply to message #531605] Fri, 27 August 2010 12:01 Go to previous messageGo to next message
Ante is currently offline Ante
Peter Stadler wrote on Wed, 05 May 2010 10:15
Peter
I also had this same problem on a fresh install of the eclipse helios SOA platform package on a linux x64 fedora 11 OS.
I tried Peter's solution; installing the BPEL Designer through swordfish's update site. This worked for me and i was able to read WSDL files necessary for project creation.
thanks Peter Smile
best regards
ante
Re: Failed to create web services using swordfish tooling UI [message #578693 is a reply to message #521537] Thu, 18 March 2010 02:38 Go to previous messageGo to next message
Member
Cheers
Jürgen
Re: Failed to create web services using swordfish tooling UI [message #578756 is a reply to message #531605] Thu, 06 May 2010 01:38 Go to previous messageGo to next message
Member
Hello Peter,
Kind regards
Jürgen
Re: Failed to create web services using swordfish tooling UI [message #578809 is a reply to message #578756] Sun, 09 May 2010 07:36 Go to previous messageGo to next message
Hello Jürgen,
Greetings
Peter
win32
-ws
win32
-arch
x86
-showsplash
-launcher
-name
Eclipse
--launcher.library
-startup
-product
-vm
-Xms40m
-Xmx256m
file.separator=\
line.separator=
os.arch=x86
os.name=Windows XP
os.version=5.1
osgi.arch=x86
osgi.bundles=reference:file:javax.transaction_1.1.1.v2010021 11330.jar,reference:file:mailto: org.eclipse.equinox.simpleconfigurator_1.0.101.R35x_v2009080 7-1100.jar @1:start
osgi.nl=de_CH
osgi.os=win32
osgi.ws=win32
path.separator=;
sun.desktop=windows
user.country=CH
user.language=de
user.name=pst
user.variant=
*** Features:
org.eclipse.core.databinding (1.2.0.M20090819-0800) "JFace Data Binding&q
Re: Failed to create web services using swordfish tooling UI [message #578889 is a reply to message #578809] Tue, 11 May 2010 03:29 Go to previous messageGo to next message
Member
8) WOW ...
Re: Failed to create web services using swordfish tooling UI [message #579177 is a reply to message #531605] Fri, 27 August 2010 12:01 Go to previous message
> Peter
thanks Peter :)
best regards
ante
Previous Topic:Swordfish and JMS
Next Topic:Swordfish FlightBooking demo with BPEL not working
Current Time: Tue May 21 14:26:55 EDT 2013
Powered by FUDForum. Page generated in 0.02394 seconds
