Home » Eclipse Projects » Voicetools » How vxml file is generated from war file?
How vxml file is generated from war file? [message #20955] Fri, 28 November 2008 01:19 Go to next message
Soumyadipta is currently offline Soumyadipta
Is there any document/help available regarding how openmethods work after
deploying the war file into the tomcat server?
I have created a application Hello and the war file is test.war. I am
accessing my application from IE as http://192.168.10.143:2117/test/hello
but i get 404 page not found.
Inside test folder
in web apps there is WEB-INF and inside that a web.xml file.
Can any body please explain this directory structure and function of each
block.
Samba
Re: How vxml file is generated from war file? [message #520285 is a reply to message #20955] Thu, 11 March 2010 14:56 Go to previous messageGo to next message
jkc is currently offline jkc
I am also getting a 404 error. Should there be something other than the META-INF folder in the war file?
Re: How vxml file is generated from war file? [message #524033 is a reply to message #520285] Tue, 30 March 2010 08:23 Go to previous messageGo to next message
My problem was solved by installing OpenMethods as opposed to just trying to update my existing Eclipse installation.
Re: How vxml file is generated from war file? [message #579126 is a reply to message #20955] Thu, 11 March 2010 14:56 Go to previous messageGo to next message
Re: How vxml file is generated from war file? [message #579139 is a reply to message #520285] Tue, 30 March 2010 08:23 Go to previous message
Previous Topic:Telera Property?
Next Topic:Deploying an OpenVXML on Apache Tomcat
Current Time: Sat May 25 02:40:54 EDT 2013
Powered by FUDForum. Page generated in 0.01733 seconds
