Home » Eclipse Projects » EGit » Most egit functionality grayed out...
Most egit functionality grayed out... [message #578603] Thu, 25 March 2010 14:25 Go to next message
buzzkill is currently offline buzzkill
Obviously, I must be doing something wrong here...
All functionality that modifies a local/cloned repository is grayed out... Also, no label or icon decorators are being shown. I can do compares using Compare WIth->History... But, that's about it.
I'm trying to use a cloned remote repository that I've imported using EGit (using git+ssh). The import works fine. I can use all Git commands from the command line and git-gui on that repository, but not from egit.
Is there some kind of permission issue here? Or are there issues with EGit and CDT?
We just switched over from SVN to Git in our dev environment. It would be nice for our eclipse users to use EGit.
I'm using Eclipse 3.5 with CDT and Egit 0.7.1 using ubuntu 8.0.4.
David
Re: Most egit functionality grayed out... [message #578632 is a reply to message #578603] Fri, 26 March 2010 01:12 Go to previous messageGo to next message
Michael Heuberger is currently offline Michael Heuberger
Member
Same to me, I just updated to 0.7.1 in Zend and most commands are greyed out.
And there is a crash when trying to add a folder to version control. Here I am pasting the stacktrace:
eclipse.buildId=unknown
java.version=1.5.0_11
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_NZ
Command-line arguments: -os win32 -ws win32 -arch x86
Error
Fri Mar 26 17:09:26 NZST 2010
Add to Version Control failed
java.lang.reflect.InvocationTargetException
at org.eclipse.egit.ui.internal.actions.Track$1.run(Track.java: 45)
at org.eclipse.jface.operation.ModalContext$ModalContextThread. run(ModalContext.java:121)
Caused by: org.eclipse.core.runtime.CoreException: Failed to add resource.
at org.eclipse.egit.core.Activator.error(Activator.java:50)
at org.eclipse.egit.core.op.TrackOperation.run(TrackOperation.j ava:130)
at org.eclipse.egit.ui.internal.actions.Track$1.run(Track.java: 43)
... 1 more
Caused by: java.lang.NullPointerException
at org.eclipse.egit.core.op.TrackOperation.run(TrackOperation.j ava:75)
... 2 more
Hope you guys can apply a patch asap so that I can continue with my work. Thanks!
Michael
Re: Most egit functionality grayed out... [message #578962 is a reply to message #578603] Thu, 08 April 2010 11:30 Go to previous message
Stefan Lay is currently offline Stefan Lay
"buzzkill" <destrozyk@yahoo.com> wrote in message
news:hog9rf$hra$1@build.eclipse.org...
Can you point us to such a repository which causes problems? I would suppose
that EGit may have problems with some special features of git.
> and CDT?
Permission is not a problem, everything is local on your machine after
cloning. I do not know issues with CDT.
Great!
Stefan
Previous Topic:Preferences->Label Decorations->Git won't "stick"
Next Topic:Team menu does not offer Share Project option
Current Time: Wed May 22 23:07:44 EDT 2013
Powered by FUDForum. Page generated in 0.05769 seconds
