| Classloading issue [message #578309] |
Fri, 30 January 2009 02:48 |
Velganesh Subramanian Messages: 59 Registered: July 2009 |
Member |
I followed the PingPong example as given in Riena RC2 download. I ran and
go the pings!
I tried the same approach to implment my functionality. I also have
common, client, config and server plugins. I am developing a plugin
similar to Eclipse UDC. I want to take advantage of Riena's Attachment to
pass the file to a server.
When I run the client, the config plugin is in RESOLVED state. When I said
start on it, it threw an exception saying that the interface present in
common project is not visible for the class loader. What am I doing wrong?
Should I declare any buddies? I am exposing the package containing the
interface in common plugin's manifest. I also came across the use of
Injector. Do you have an example?
FUDForum. Page generated in 0.01443 seconds
