Home » Eclipse Projects » Eclipse 4 » TestCase failures and incomplete UI and functionality for Eclipse 4.0 M6
TestCase failures and incomplete UI and functionality for Eclipse 4.0 M6 [message #578004] Sat, 19 June 2010 02:31 Go to next message
ratish  is currently offline ratish
The setup for Eclipse 4.0 M6 (eclipse-SDK-4.0M6-win32.zip) at http://download.eclipse.org/e4/sdk/ shows Test Case failures
When I complete the setup, I see incomplete UI and functionalities. Any idea, when will the next build be available with the fixes
Re: TestCase failures and incomplete UI and functionality for Eclipse 4.0 M6 [message #578023 is a reply to message #578004] Mon, 21 June 2010 09:19 Go to previous message
Paul Webster is currently offline Paul Webster
We're publishing RC0 today. http://wiki.eclipse.org/E4/Self_Hosting has
the list of known issues that need to be worked on for 4.0
PW
Paul Webster
http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .platform.doc.isv/guide/workbench.htm
Previous Topic:Where does TableViewer select an entry?
Next Topic:TestCase failures and incomplete UI and functionality for Eclipse 4.0 M6
Current Time: Sun May 19 07:08:50 EDT 2013
Powered by FUDForum. Page generated in 0.01622 seconds
